Results 1 to 21 of 21
    Bar ends: Any recommendation?
    Austin, Texas
    None unless you are riding a marathon. Seriously, more garb to get jabbed, poked or impaled.
    Five is right out
    Bar ends with a slight curve are more comfortable for longer climbs. Otherwise, they are all pretty much the same.
    Since when did the phrase "invest in" come to mean the same as "buy"?
    if you don't want to worry about getting poked or snagging on something you can't go wrong with the stubby's...
    Five is right out
    I should have added that stubbies (and Cane Creek Ergos) are pretty useless for moving your weight forward for climbs. Bar ends are dirt cheap- just get some Profile Designs (or other bog-standard bar end) and see how you like them.
    I use old fashion long bar ends with curve. Most convenient for moving weight forward and least prone to get caught in shrubs. Install them at angle 5-10 degree down of the horizon.
    Rod
    Rod is online now
    Reputation: Rod's Avatar
    Oct 2007
    I use the Cane Creek Ergos that the guy is hating on above me. I like them and they have a rubber grip so your hands/ gloves won't slip. I have also never caught them on anything. I ride with a 120mm stem so that may be why I don't see a problem. With such a long stem my front tire stays on the ground.
    There is not much choice between rotten apples.
    lol! theres always gotta be a hater...i too have never had any problems with my stubby's.
    bi-winning
    Reputation: rkj__'s Avatar
    since 4/10/2009
    Reputation: Harold's Avatar
    I personally don't like bar ends.
    wyrd bi ful rd
    Reputation: chinaman's Avatar
    Never trust a fart
    Reputation: frdfandc's Avatar
    I use the old tried and true Profile Design with the slight curve. I haven't caught anything on them in the numerous years I've been using them.
    MTB Rider
    Reputation: willtsmith_nwi's Avatar
    Jan 1970
    Big ole Titec L-bends. More hand positions and they effectively protect your hands from any tree strikes. If they hook anything ... you were going down anyway.
    Rod
    Rod is online now
    Oct 2007
    Quote Originally Posted by puffdc
    It's good to see I'm not in the boat alone against the hater. I don't really see how someone could have a problem with these bar ends. They're not long enough to catch anything and if they did catch something whatever caught the bar end was going to catch the handlebar anyways. They provide a different hand position and I can get more leverage when using them to climb. I don't have any complaints with them.
    Rod
    Rod is online now
    Oct 2007
    Quote Originally Posted by NateHawk
    I can see your point. Like I've said I haven't had any problem with mine, but I have big hands so my hand rubs on my rubber bar end. I have recently started wearing gloves, but it's not much better. I like the bar ends for the added hand positions, but I also don't like it because my hands almost feel trapped b/c they're so big. I may take them off soon to see if I'm more comfortable without them. There's always something positive and negative about every part.
    I own a pair of the ergons. The do tend to get caught on vines from time to time. They have 2 options when u buy them, short and long. I have the short ones and they are nice for an extra hand position, but pretty worthless if you want to shift weight around like longer bar ends.
    On MTBR hiatus :(
    My favorites are from LP Composites <i>Braids</i>. A little pricey compared to some of the other options, but damn comfortable.
    I like my bar ends for stretching out in front of the bike, so have little use for stubby offerings -- otherwise, the Cane Creek ergo-turds are awesome.
    And there's no reason you can't use Ergon's comfy grips with any other brands' bar ends.
    <img src="https://www.trails-edge.com/retail/bikeparts/barends/lp_grips.jpg">
    speedub.nate
    MTBR Hiatus UFN
    MTB Rider
    Jan 1970
    I'll tell you what ALL bar ends need. They all need lock on grip slots. That way you shorten up your grips and use the bar end clamp for a grip clamp.
    Reputation: limba's Avatar
    Ritchey WCS. Small and light.
    For single track rides, I don't use bar ends. For longer gravel metric or standard centuries, I will use them to give myself a change in hand position on longer straight stretches of road. With the bar width that I have on my KM, I didn't like the twichiness of the handling I had when riding with the bar ends this winter. Not enough leverage for my tastes. To each his own on whether or not to use them. As for the ends themselves. I use the profile designs ones. They were cheap, they work, and they come on/off the bike easily.
    Probably drunk right now
    Reputation: Ken in KC's Avatar
    What you read and what they said...
    Quote Originally Posted by Rod
    Easy. What you read was "Cane Creek Ergos suck". What Womble said (in fewer words) is that one of the advantages to bar ends is you get multiple hand positions, including moving out in front of the bar: "I should have added that stubbies (and Cane Creek Ergos) are pretty useless for moving your weight forward for climbs."
    Womble is correct. For moving your weight forward for climbs, stubbies are not effective.
