24 Speeds Needed?- Mtbr.com
Results 1 to 13 of 13
    24 Speeds Needed?
    I find when I'm out on the bike (trails, road and light XC) I stay almost exclusively on the big ring. I also find that I sometimes don't have a high enough gear on flat roads or descents. I have been wondering lately how I could get a higher gear and how simple it would be.
    Today I was watching the UCI MTB World Cup in Yorkshire and heard the commentators say that some of the riders had done away with the front mech altogether and just have a big ring up front - 1x10
    Has anybody got any experience of this setup and how simple would it be to adopt this system on my GT Avalanche?
    Reputation: SwampDonkeyDisco's Avatar
    Go up hills more...you will see more usage of the other rings.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Yep , start your ride with a 2000 ft. climb and the value of a couple more chainrings shows itself .
    I run a 1X9 with a 32 up front. I like it alot. Where I ride dosent have much flat though.
    MUD
    My weiner is 10.5".....Oh wait...I'm holding this ruler backward.
    Teen Wolf
    Reputation: cr45h's Avatar
    1x9's are super popular, or do singlespeed.
    Reputation: mb-matt's Avatar
    I went 1x9 last year and love it. But it make a difference as to what the terrain you are riding is like.
    Reputation: Brujo's Avatar
    i could get rid of my big ring up front and i mostly ride in the small and middle ring, it seems out of the 24 speed that are available to me, i only use 6
    2009 Giant Yukon FX
    Yeah, I think a 1x9 setup would work fine for me. Next ride I go on I'm gonna try not using the front shifters at all and see how I get on. Throw in some hills etc, although when I go on hills now I stay pretty much on the big ring and just knock the rear down to mid-cassette.
    What would I have to do to implement this - is it just a case of removing the front mech/derailers? Seems like a win win. less weight, fewer things to go wrong and more space on my handlebars.
    jalopy jockey
    U R a BEAST!
    Go ride 50-100 miles in some hilly country and post again please.
    This thread was a simple request from other users as to their experiences using one ring on the front. Any salient advice they could offer on implementing such a system and what I would need to do to get a higher gear ratio..
    Comments such as 'you're doing it wrong' or 'move to another country' are not useful. If you have a constructive comment then please feel free to share it.
    fresh fish in stock...... SuperModerator
    Reputation: CHUM's Avatar
    to get a higher gear you need to get a bigger tooth count on your front ring - but in doing so you will be giving up clearance on your sawblade....so rocks/logs may (will) contact/bend/scrape/bounce over obstacles a whole lot more....
    you can also switch to a 29" bike....that'll up the gearing without giving up aforementioned clearance issues...
    my .02
    Click Here for Forum Rules
    Disgruntled Peccary
    Reputation: dysfunction's Avatar
    You're not going to have as big a big ring as on a road bike, you could see if you can get a 54 etc.. but while that will keep you from spinning out on flats and descents, it's pretty drastically different from the 1x9/1x10 setups... and as I recall.. Yorks isn't the flattest place on earth.
    mike
    Thanks Chum & Dysfunction
    This is all speculative for now till I have a bit more cash to spend. I'm definitely looking at a single on the front and maybe a slightly larger cog too. I'll visit the LBS to see options.
