2014 Nimble 9 BUILD need help- Mtbr.com
Results 1 to 6 of 6
    Apr 2014
    So currently I ride a 09 Scott Spark 60 Not the greatest bike but it has served me well in the last few years that I have had it.
    Build budget was 2000 now 2500
    Anyways I want to build up a Nimble 9 into a 1x10 AM setup. my biggest concern is just making sure everything works with everything else on the bike especially the wheels with the rotors, the headset with the frame and fork, bottom bracket and the crank and frame, rear derailleur and the frame. So basically everything fitting together properly and not having to return anything.
    I currently am thinking a 140 tower pro up front
    180 rotors up front 160 in the back
    not too worried about tubeless so I was thinking the canfield bros 29er wheelset
    Everything else I have know idea... Help me out
    Reputation: Shakester's Avatar
    Jun 2012
    Not sure if this would help since, but Canfield has some basic build specs:
    2014 Nimble 9
    Recommend fork lengths 100mm 140mm
    Headset 44mm upper and lower cups
    Front derailleur Shimano direct mount top pull/single bolt, or Sram HO series
    Bottom bracket 73mm
    Seatpost 27.2mm
    Seatpost clamp 29.8mm
    Rear dropout spacing 142x12mm, Maxle included
    Post brake mount
    Apr 2014
    Yeah I have been going back to that but I've never seen so may different ways things mount and different sizes for everything. It seems every bike company has a different way of mounting things and don't even get me started on wheelsets
    lie
    lie is offline
    Apr 2014
    Ive been hammering mine like a Dh fork and they've been nothing short of awesome. Only thing that bugs me is the axle clamp sometimes likes to work itself loose (while also being hard to release at the same time?). Just need to keep an eye on it, or when its in closed position tighten the allen key on the quick release lever fully tight so it can't move.
    Only thing i will say is proper tuning needs to be done on the trail, carpark tuning just doesn't work well with these forks. People often sit on my bike and say your forks feel sticky/odd.. but then when they ride it at speed they are pretty amazed at the control.
    Service parts can be had (NS etc had a few).
    Apr 2014
    Also looking at a Reba at the moment but I think I figured out most of the bike for ment things. Headset sill worries me a little but if I get something wrong I can order something different and it's a learning experience I guess.
    Jun 2012
    You can run an Cane Creek EC44/30 if you want to a fork with a straight steerer tube. You can get the ZS44/EC44/30 to runs tapered fork.
    Universal Cycles -- Cane Creek 40 ZS44/EC44/30 Headset - Fits 1 1/8" Forks
    Universal Cycles -- Cane Creek 40 ZS44/EC44/40 Conversion Headset - Fits 1.5" Tapered Steerers
  1. Canfield Nimble 9 build thread!
    By sslos in forum 29er Bikes
    Last Post: 11-24-2018, 06:51 PM
  2. 2013 Nimble 9 Build Thread!
    By Aaron1017 in forum Canfield
    Last Post: 11-21-2016, 01:45 PM
  3. 2014 Canfield Brothers Nimble 9
    By KillingtonVT in forum Canfield
    Last Post: 05-29-2015, 11:16 AM
  4. Replies: 7
    Last Post: 11-13-2013, 02:27 PM
  5. Nimble 9 build Advice
    By VertKurt in forum Canfield
    Last Post: 01-25-2013, 06:23 PM
