Hey guys, I've been reading this forum for a while now and I need some input. I've basically narrowed my choices down to a Trek 4300, Trek Gary Fisher Marlin, and the Specialized Rockhopper. I went to the LBS today to test ride the Rockhopper. I did not get a chance to ride them because I wanted to ride a 19" (I'm 5'-10) and they had to order one, so I'm going back on Friday to ride a 17" / 17.5" / 19". I plan on test riding the Trek and GF tomorrow. However, the LBS with the Specialized has a 2010 Comp @ $699 and a 2011 (regular) @ $629. The guy mentioned that they could make me a deal on the 2010 Comp if I was interested (he didn't say how much). From looking online, I can really only see that the major difference is the better front fork on the Comp. Is there any other real significant differences between the two other than the color schemes? What kind of discount should I be looking for in a two year old new bike? Thanks for any input.
2010
Specialized M4 fully manipulated alloy frame, fully butted, ORE DT, externally relieved HT, forged dropouts w/ replaceable derailleur hanger, disc only
REAR SHOCK
FORK
RockShox Dart 3 SL, 80/100mm, 1 piece magnesium lower, alloy steerer, adj. reb. damping w/ LO and preload adj., size-specific spring rates, disc only
HEADSET
1-1/8" threadless, loose ball
STEM
3D forged alloy, 7 degree rise, 31.8mm clamp
HANDLEBARS
Butted alloy riserbar, 25mm rise, 660mm wide, 8 degree back sweep, 7 degree up sweep
GRIPS
Specialized Enduro, dual compound Kraton, no flange, 131mm
FRONT BRAKE
Avid BB5, mechanical disc, 160mm G2 Clean Sweep rotor
REAR BRAKE
BRAKE LEVERS
Avid FR-5, alloy, two-finger linear pull
FRONT DERAILLEUR
Shimano Altus, 34.9mm clamp
REAR DERAILLEUR
SRAM X-5, mid cage
SHIFT LEVERS
SRAM X4-R trigger
CASSETTE
SRAM PG-830, 8-speed, 11-32t
CHAIN
KMC X8 w/ reuseable Missing Link
CRANKSET
SR SunTour, Octalink spline
CHAINRINGS
42S x 32S x 22S replaceable
BOTTOM BRACKET
Shimano BB-ES25, Octalink spline, cartridge bearing, 68mm x 118mm
PEDALS
Steel cage, composite body, 9/16"
RIMS
Alex RHD 26", pinned, alloy double wall, eyelets, 28h front and 32h rear
FRONT HUB
Forged alloy, hi/low flange, double sealed, ground race, machined disc mount, 32h
REAR HUB
Forged alloy, double sealed, ground race, machined disc mount, cassette, 32h
SPOKES
2mm (14g) stainless
FRONT TIRE
Specialized Fast Trak LK Sport, 26x2.0", 60TPI, wire bead
REAR TIRE
INNER TUBES
Schraeder valve
SADDLE
Specialized Rockhopper XC, Body Geometry, 143mm width, front and rear bumpers
SEATPOST
Alloy two bolt, 12.5mm offset, micro adjust, 30.9mm
2011
FRAME Specialized M4 fully manipulated alloy frame, fully butted, externally relieved HT, forged dropouts w/ replaceable derailleur hanger, disc only
FORK SR Suntour SF11-XCR-DS-26-LO-SP, mag. lower, 30mm steel stanchions, hyd. damping w/ lock out and custom tuned spike valve
HEADSET 1-1/8" threadless, loose ball
STEM 3D forged alloy, 7 degree rise, 31.8mm clamp
HANDLEBARS Butted alloy riserbar, 25mm rise, 8 degree back sweep, 6 degree up
GRIPS Specialized Enduro, dual compound Kraton, no flange, 131mm
FRONT BRAKE Avid BB5, mechanical disc, 160mm G2 Clean Sweep rotor
REAR BRAKE Avid BB5, mechanical disc, 160mm G2 Clean Sweep rotor
BRAKE LEVERS Alloy, linear pull
FRONT DERAILLEUR Shimano Altus, 34.9mm clamp
REAR DERAILLEUR SRAM X.5 8sp Mid cage
SHIFT LEVERS SRAM X.4 trigger
CASSETTE SRAM PG-830, 8-speed, 11-32t
CHAIN KMC X8 w/ reusable Missing Link
CRANKSET SR SunTour, Octalink spline
CHAINRINGS 42S x 32S x 22S replaceable
BOTTOM BRACKET Shimano BB-ES25, Octalink spline, cartridge bearing, 68mm x 118mm
PEDALS Plastic platform, toe-clip compatible, reflectors, 9/16"
RIMS Alex RHD 26", alloy double wall, pinned w/eyelets
FRONT HUB Forged alloy, hi/low flange, double sealed, ground race, machined disc mount and flange, QR, 28h
REAR HUB Forged alloy, mid flange, double sealed, ground race, machined disc mount and flanges, cassette, QR, 32h
SPOKES 2mm (14g) stainless
FRONT TIRE Specialized The Captain Sport, 26x2.0", 60TPI, wire bead
REAR TIRE Specialized The Captain Sport, 26x2.0", 60TPI, wire bead
INNER TUBES Presta valve
SADDLE Specialized Rockhopper XC, Body Geometry, 143mm width, front and rear bumpers
SEATPOST Alloy two bolt, 12.5mm offset, micro adjust, 30.9mm
