Zero Stack & Trad Mix Headsets for Spitfire- Mtbr.com
    Calm like a Bomb
    Reputation: stunzeed's Avatar
    So its looking like i want to run a 150 fork on a Small Spitfire , I was wondering if anyone found a Cane Creek headset combo to run Zero Stack up top and a Traditional Cup on the lower. Is there anything special about the spitfires HT?
    Would like to run this up top
    http://www.universalcycles.com/shopp...6&category=724
    Lower cup to be:
    http://www.universalcycles.com/shopp...5&category=724
    That setup would work. I believe from cane Creek you can buy top and bottom seperately.
    Banshee Bikes Designer
    www.bansheebikes.com
    Banshee Blog
    Calm like a Bomb
    if i decide to run my 160mm fork, on a small frame using a Zero Stack Lower Cup..can you confirm that the fork clears the frame without issue?
    should work fine.
    Banshee Blog
