will a 28T chainring fit a 2015 banshee rune??- Mtbr.com
Results 1 to 5 of 5
    has anyone tried a 28T chainring on a 2015 banshee rune? will there be enough clearance for the chain with the lower part of the chainstay?
    Reputation: LyNx's Avatar
    In what position on the crank if it's a double or triple with bash and what chainline crank? From my experience with my Phantom and Prime, if I tried to run a 28t ring in the inboard "granny ring" position of my 104/68 BCD 51mm chainline cranks, it would definitely hit the stays, if I ran one using a spiderless crankset in the "middle ring" position, no issues at all.
    Quote Originally Posted by bendik.ph View Post
    Quote Originally Posted by Harold
    You're doing mtbr wrong, you're supposed to get increasingly offended by the implications that you're doing ANYTHING wrong.
    Dec 2016
    My wife rocks a 28T. It is close on the chainstay drop. Put some mastic tape on the chainstay and you will be fine.
    Thank you LyNx. I am currently using a 32t single ring with 11-36t and zee short cage at the rear. i will definitely go 28t for easier climbs.
    Quote Originally Posted by chuckiebruster View Post
    yes, some tape and a few zip ties. thank you chuckiebruster
  1. Rune Spam: Medium 2015 Rune, CCDBAirCS, Headset
    By S Dub in forum Banshee Bikes
    Last Post: 06-29-2016, 11:45 AM
  2. Does a 28T or 30T 104BCD chainring exist?
    By mtnbiker72 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-22-2014, 06:25 PM
  3. Rune/Spitfire - Clearance with 1x10 and 30T or 28T?
    By in the trees in forum Banshee Bikes
    Last Post: 09-28-2013, 09:27 AM
  4. 1x9 5spot with a 28t granny god chainring and bash?
    By Tim Mailloux in forum Turner
    Last Post: 01-21-2012, 04:19 PM
  5. Fit...Fit...Fit questions (bike fit, that is!)
    By Alan in forum General Discussion
    Last Post: 04-02-2007, 07:06 AM
