V2 Spitfire 650 tire in 26 dropout - what clears?- Mtbr.com
Results 1 to 6 of 6
    Sep 2013
    Thinking about ordering some 26" dropouts to test shorter chain stays with 27.5 tires. I've been digging through threads but haven't found any info on the tires I'd be running. Specifically I use Spesh Butcher 2.3s on 25mm internal rims (WTB I25s). Anyone have experience with those or DHF 2.3s (similar profile)?
    In general, what has worked for you and what hasn't?
    smartass
    Reputation: amish_matt's Avatar
    A DHR2 on an i30 rim clears fine.
    Hard funkinī Kraut
    Reputation: NoStyle's Avatar
    May 2005
    The tightest area is the square middle brace! A Schwalbe HansDampf 2.25, or a 2.3 Maxxis HighRoller II fits there, with a clearance of 6 - 8mm in the neutral geo-setting. Clearance changes about +/- 2 - 3mm, depending of the chip-setup.
    DHR2 2.3 worked fine for me, you shouldn't see any problems with any 2.3 from Maxxis.
    kts
    kts is offline
    Butcher on Flow EX and Ground Control on 30mm id LB rim clear everything fine.
    Sep 2013
  1. Any guesses what the Owyhees will look like when to smoke clears?
    By Ditchbanker in forum Idaho, Montana, Wyoming
    Last Post: 08-20-2015, 08:34 PM
  2. Becon Hill Bike Park Clears Committe
    By Dave_schuldt in forum Washington
    Last Post: 07-26-2014, 09:55 AM
  3. Replies: 9
    Last Post: 10-10-2013, 09:15 AM
  4. Replies: 5
    Last Post: 10-22-2012, 05:11 PM
  5. Replies: 7
    Last Post: 05-24-2012, 02:38 PM
