V2 Dropout Hanger Loose- Mtbr.com
    Aug 2005
    I'm assembling the dropouts on my Rune which has boost v2 dropouts.
    With the bolt screwed in all the way to the hanger, it can slide back and forth. I assume not a problem once the wheel is in there.
    Is this normal? Below is a pic, can see the extra space.
    Dec 2016
    Quote Originally Posted by Canadmos View Post
    Not normal. The bolt should be flush with the dropout. Carefully check that you have not cross threaded the bolt. I think the factory loctite makes it seem like it is a bit tougher to thread in than expected. Just be very careful!
    Aug 2005
    Quote Originally Posted by chuckiebruster View Post
    Yeah it felt like it was bottoming out, so I just stopped. I gave it the beans (gently) and now its fully seated. There was quite a bit of dried threadlocker gooped onto the threads...
    Dec 2016
    Nice work!
  1. Pivot Mach 4 frame/dropout stripped @ hanger bolt - 2010
    By Rollin'in'Zona in forum Pivot Cycles
    Last Post: 10-30-2013, 05:43 PM
  2. WTB: Carbine Hanger / Right Dropout
    By hkenshin in forum Intense
    Last Post: 06-01-2013, 03:20 PM
  3. Replies: 3
    Last Post: 01-13-2012, 12:20 PM
  4. Bent derailluer hanger/dropout on Mt Vision
    By birdman829 in forum Marin
    Last Post: 09-03-2011, 02:22 PM
  5. Dawg Supreme Rear Hanger/Dropout-hub Fit
    By sbeishline in forum Kona
    Last Post: 02-01-2011, 05:41 PM
