Spitfire mixed wheel size geo questions.- Mtbr.com
    Reputation: juanbeegas's Avatar
    Oct 2007
    Would anyone know how to calculate what happens to the geometry of the bike, if I were to go from my current 26" set up to a 27.5f/26r? I have my dropouts in the lowest setting.
    I'm currently on a medium 2014 Spitfire with a 140mm Pike 27.5", 46mm offset and a 532mm(I think) A2C.
    Mar 2016
    Roughly speaking...
    You'll slacken the head- and seat-angle by just under half a degree. The handlebars will be about 1 cm higher, and the bb will be about 4mm higher.
    Oct 2007
    Thanks, dude.
    Aug 2014
    I ran 27.5F/26R on my 2014 for a season, with a 540mm axle-to-crown Revelation 150mm fork. I really liked the handling and quick feeling of the back end in switchbacks. 26" dropouts in the medium or low position, I can't remember.
    I now run 27.5 front and rear with 26" dropouts in the low position, plus a 10mm tall lower headset cup to slacken out the front end. Can't say if handling is better or worse!
  1. Replies: 4
    Last Post: 03-28-2017, 07:34 AM
  2. Compare Race Geo vs Modern Slack Geo
    By Afun in forum General Discussion
    Last Post: 08-17-2016, 06:44 PM
  3. early/proto spitfire frame geo?
    By PSI in forum Banshee Bikes
    Last Post: 07-19-2011, 06:48 AM
  4. whats the difference between hybrid geo and 9r geo?
    By jeffgothro in forum 29er Bikes
    Last Post: 04-14-2011, 08:15 AM
  5. Replies: 6
    Last Post: 11-12-2006, 05:19 PM
