Rune V2 Lower Pivot Axle stuck fast- Mtbr.com
Results 1 to 13 of 13
    Reputation: Phsx2's Avatar
    Dec 2014
    As you can see I've got the rest of it apart with some gentle persuasion, (soft faced hammer) but the last axle is stuck good and proper. Besides beating on it with a hammer with the nut screwed in a few threads to push it out. Any ideas as to how to get the bloody thing out?
    Reputation: Junersun's Avatar
    Jun 2014
    Are you replacing bearings? I suppose you could tap the bearings out slightly by tapping the linkage softly with a soft mallet....
    The first time I replaced my bearings mine was really on there too. I remember having to take the frame off to pull it off by pinching the frame between my legs....
    Maybe someone else has a better idea...
    Current Bikes
    2015 Transition Patrol AL
    2016 YT Tues AL
    Dec 2014
    Already tried to hammer it out, but it won't budge. I'm thinking a hydraulic press might be worth a shout. Except I don't own one.
    Wiggle the link out with some force, it will be fine.
    Dec 2014
    Link isn't going to move chief, the axle is still stuck in there.
    Jun 2014
    Oh I didn't realize you had an axle stuck in there. Sorry bud. Go to the store and grab some PB blaster, also get the same pinch bolt size (sacrificial). Blast it and let it sit for a little bit to let it work it's way in.
    Screw in the bolt most of the way in, and hit it with the mallet...
    Current Bikes
    2016 YT Tues AL
    Dec 2014
    Yep, tried that trick. Hasn't worked but, I'll keep giving it a blast of penetrating oil and giving it an occasional hammering.
    Jun 2014
    Quote Originally Posted by Phsx2 View Post
    worst case scenario, Banshee's online store has the lower link pivot axle and bearing kit so you could just hammer and pop the axle and bearing out at the same time to replace it....
    Current Bikes
    2016 YT Tues AL
    Dec 2014
    Worst case is drilling it out.
    Jun 2014
    Yep that is worst than my idea... good luck
    Current Bikes
    2016 YT Tues AL
    Braaap
    Reputation: DirtMerchantBicycles's Avatar
    May 2014
    Get a bigger hammer.
    Use a spare bolt to thread in, lay the frame horizontal with the BB on the ground, and go to town. That should be plenty, if not, apply heat to the link.
    Dirt Merchant Bicycles
    Providing unrivaled support and unbeatable pricing on all cycling goods to riders near and far.
    I had to do exactly this on my Spitfire. The axle was fused to both bearings, so you couldn't tap out one of the bearings with the axle (oh how easy). Instead, I drilled it enough to release one of the bearings, then tapped out with the other bearing. It was terrifying. And heretofore I will take out and grease my axles every 3 months or so.
    Good luck. Shout out to @DirtMerchant for hooking me up with the axle kits and a new link since I boogered mine up in the drilling process.
    http://forums.mtbr.com/banshee-bikes...a-1037131.html
    Dec 2014
    I might take my frame to a mechanics and ask to borrow their hydraulic press for a few minutes.
  1. Rune Spam: Medium 2015 Rune, CCDBAirCS, Headset
    By S Dub in forum Banshee Bikes
    Last Post: 06-29-2016, 11:45 AM
  2. Lower headtube issues on Rune V2
    By helimech in forum Banshee Bikes
    Last Post: 02-07-2013, 07:39 AM
  3. Lower than 160mm fork for Rune?
    By ride the biscuit in forum Banshee Bikes
    Last Post: 05-08-2012, 03:11 PM
  4. Blur XC- lower pivot axle "migrating"
    By essjss in forum Santa Cruz
    Last Post: 08-10-2011, 04:20 PM
  5. Stuck / Frozen Pivot Axle
    By mtbiker278 in forum Santa Cruz
    Last Post: 06-23-2011, 08:57 AM
