Prime with a DVO Topaz- Mtbr.com
Results 1 to 5 of 5
    Reputation: noosa2's Avatar
    Anyone running a DVO Topaz on their Prime? How do you like it compared to other shocks you've tried?
    Reputation: Junersun's Avatar
    Jun 2014
    Quote Originally Posted by noosa2 View Post
    I have a rune with a topaz now if that can have partially relate... with the rune I've been on ccdb coil, fox X2, dvo jade and now the topaz. I absolutely love the fact that I can tune the negative air spring to give the rune ample mid stroke support and then ramp it up hard for any heavy hitting.
    I'm thinking of adding a shim on the compression circuit and removing one negative band though. Also adding a shim to the lever assembly compression circuit to add more dynamics to the lever adjustment. Lastly removing a shim on the rebound and cranking the rebound knob up more so that my hsr circuit is fast but my lsr circuit is slower.
    Prob a little more than what you're asking but it's a great air shock for the KS linkage!
    Current Bikes
    2015 Transition Patrol AL
    2016 YT Tues AL
    Off the back...
    Reputation: pinkrobe's Avatar
    I put a Topaz on my 2017 Prime about halfway through last summer, replacing the stock Monarch shock. The result was a huge improvement in sensitivity without having to run low pressure / high sag. My only complaint is that I waited so long to make the change.
    Thanks for the info guys.
    Big Test Icycles
    Reputation: Hangtime's Avatar
    Iíll round out the comments with a Topaz on my Spitfire. Love it. Pos/neg chambers tunable, plush and very responsive to climb switch when I use it, however with the Banshee susp design I find I donít need it. My frame came with an XFusion OX2 shock that blew up when really put to the test.
  1. DVO Topaz
    By Idaho in forum Shocks and Suspension
    Last Post: 16 Hours Ago, 03:28 PM
  2. Dvo topaz on ibis hd3?
    By Joel Fitzgerald in forum Ibis
    Last Post: 12-02-2017, 08:35 AM
  3. Replies: 4
    Last Post: 06-29-2016, 03:40 PM
  4. M6 and dvo topaz?
    By Dax Olivares in forum Pivot Cycles
    Last Post: 05-10-2016, 04:06 PM
  5. DVO Sapphire and Topaz
    By max_lombardy in forum Shocks and Suspension
    Last Post: 02-02-2016, 08:37 AM
