Phantom sizing help- Mtbr.com
Results 1 to 16 of 16
    Jun 2018
    Phantom sizing help
    Hello all,
    I'm needing some help with sizing. I'm on the shorter side at 5' 5.5" with 29" inseam and considering a phantom. My main concern is that the medium might be too big?
    Would like to here experiences of any shorter riders on the phantom (or prime).
    A little background. I've only been riding for the last year and don't have much experience with a lot of other bikes to know what I love and don't love about various geometry charts. I'm also not in an area that has a lot of bunch of FS bikes to demo. I'm riding a Cannondale Cujo 1 (sm) 27.5+ with a reach of 383. I feel comfortable on the Cujo but don't think I'd have an issue with an additional inch of reach. Although I know that reach isn't everything.
    Mostly riding flat to flowy singletrack trails with some roots, shorter climbs and descents and nothing crazy technical. No interest in racing. Just try to maximize fun every time we (12 y/o and I) go out and ride.
    Thanks for any input.
    Nor­wegr
    Reputation: Vegard's Avatar
    Reach on the current medium Phantom is 426mm, you'd have to get very lucky on the cockpit to make that work for you I believe. What you could do is try and look for one that's a couple of years old to get shorter reach.
    For reference I'm 5'7 and on a medium Prime from 2015, got the frame nib recently for the specific reason of having shorter reach [411mm], and that it was cheap .
    It feels better on the type of trails I enjoy.
    Honestly I'd recommend a small Spitfire for you. It will be more fun for you to ride and be a better fit all round. At 5'5.5" those big 29" wheels can be difficult to ride with. You'll have more confidence on the spitfire as a result, and find it easier to handle.
    Banshee Bikes Designer
    www.bansheebikes.com
    Banshee Blog
    Reputation: LyNx's Avatar
    You didn't list the cockpit setup on your current SM, what length stem and width bar, but going to assume that it's a mediumish length stem, probably 60-70mm, so you could drop to a 35-40mm stem or maybe even a 50mm if you like to be stretched out and feel fine.
    I am a believer in wheel size to suit body size, that being said, I think a Phantom would be a good bike for you - efficient suspension, climbs real well, good geo and descends as good, would serve you for a good few years, maybe more. Standover shouldn't be an issue, I've let people a bit taller than you on my Large Phantom and XL Prime and they had room, so should be plenty on the M.
    I kind of shy away from the Spitty because of it's quite a bit more travel, not sure it would be as nice to pedal around for general light trail riding/XC like the Phantom, but then the Phantom can rip the downs. Keith and I are on the opposite side of the fence in terms of riding style, so he prefers the smaller wheels for a more poppy, playful ride, but I guess being 6'2" and not liking hitting anything over 3ft, love chunky, slow tech, I don't have much issue with the Phantom's playfulness, my first ride out on it I couldn't believe the difference between it and the Prime.
    Quote Originally Posted by Harold
    You're doing mtbr wrong, you're supposed to get increasingly offended by the implications that you're doing ANYTHING wrong.
    Reputation: S​​usspect's Avatar
    May 2017
    Another reference point, I'm 5' 8" on a newer model phantom. I actually went from a 50mm to a 70mm stem to open up the cockpit a bit, and been riding like that ever since.
    With your inseam, you might find you're limited to a 125mm dropper. I can't remember my bike inseam offhand (32"?) but my pants inseam is 30" and I use a 125mm dropper, may be able to fit 150 from some brands but I tried a Fox Transfer at first and it was a bit too long for where I wanted my saddle.
    But one area the phantom would fit you perfectly would be your goal to "just try to maximize fun every time we (12 y/o and I) go out and ride".
    The builder recommends you try the spitfire... you'd probably love it. It's a different bike though, with a lot more rear travel. If you can't test ride the banshee, maybe you can find a bike with the same 426mm reach and see how it feels?
    Jun 2018
    Thank you for all of the input so far. I definitely understand where Keith is coming from suggesting a smaller spitfire. At my height, 27.5 versus 29 is something I debate. Currently I'm riding a 27.5+ and don't think there will be a huge difference to 29er. Also, there isn't a lot of overly tight switchbacks. I do fine on the plus bike so hoping the 29 wouldn't be too different.
    Lynx - I believe it is roughly a 60 mm stem, I will have to check whenever I get back home. The bars are 760 mm and also running a 120 mm drop post.
    For whatever reason I seem to be drawn more towards the short travel 29er. Around here, Oklahoma, 29ers seem to be the go to and there's mostly xc type of riding. Therefore, I doubt I'd "need" more than 130/120 f/r travel.
    Jenson does have a nice deal on a spitfire in small so it's intriguing but yes, a different type of bike.
    Outerbike is coming to Bentonville in October so the smartest thing might be to hold out and make the 4 hour trip and ride everything I can get my hands on. It looks like MRP might spec some of their forks on various banshee models.
    Yes, MRPs demo fleet includes several Banshee's, probably a good idea to check with them and see if by chance they have a Medium Phantom in the lineup. If you're happy on B+, then I think you'll really dig a regular 29er like the Phantom with some nice 22.3-2.4" rubber, should feel quite a bit snappier handling actually. Another "plus" of the Phantom is you can also easily swap your B+ wheels into it and give that a try and basically get 2 quite different feeling bikes, more so depending on what whels and tyres each wheelset is made up of.
    Quote Originally Posted by Mcsquared33 View Post
    May 2017
    I live right around Bentonville, if you make it up here before October hit me up and we can work out a ride/let you try out my phantom.
    Jun 2018
    Quote Originally Posted by JScoot View Post
    Awesome, I appreciate that. We are going to stay in Bentonville a day or two in early August and plan to do some riding on our way to Big Cedar.
    And this is why the mtb community rocks! Love it!
    Banshee Blog
    May 2017
    Sent you a pm.
    Jun 2018
    Sent you a pm.
    Doesn't appear that I received it
    May 2017
    Resending from an actual computer.. this should work better.
    I could use some help on this too. I'm 6'1" with a 34" inseam. Stuck between L and XL always. For reference, my 2018 Kona Process 153 29er was L and felt great. My Guerrilla Gravity The Smash is L and feels a bit stretch out. Both of these are known to be long and big bikes though. I test rode an XL and L Giant Trance 29 today and I think I liked the L better. It's mainly a reach thing, I don't like to be super stretched out. But the problem comes when I had a L yeti SB4.5. It felt a little cramped and perhaps an XL here would've been better.
    Feb 2007
    you will get different answers - ! am 185 cm with a 85 cm inseam and I am riding a 1st gen Phantom in L and a 50 mm stem....reach could be slightly longer but I like it that way. Not a fan of a mega long reach though.....
    Quote Originally Posted by rushy41 View Post
    Thank you! I am leaning towards a L. The XL is just so much bigger. And agreed, I'm not a fan of monster reaches. It's ones reason I am not sad about moving on from my Smash
  1. Phantom pivot kit and shock hardware...can you help?
    By badgermtb in forum Banshee Bikes
    Last Post: 07-12-2017, 03:35 PM
  2. Replies: 22
    Last Post: 04-01-2017, 06:54 PM
  3. Phantom sizing help...
    Last Post: 11-04-2016, 10:35 AM
  4. Motobecane Phantom Cross Pro Ti Sizing
    By salimoneus in forum Cyclocross
    Last Post: 10-24-2015, 08:08 AM
  5. Help with Schwinn Phantom "Clunker" sizing
    By robinsmith in forum Vintage, Retro, Classic
    Last Post: 04-23-2008, 09:55 AM
Members who have read this thread: 7
