Monarch Plus - how many volume spacers?- Mtbr.com
Results 1 to 3 of 3
    Riding a Prime, pulled my shock apart because my Monarch had the all too common leak past a ring into the negative chamber and I was stuck down in the travel. Anyways, all well there I'll get it sorted, but while I am in there I realized I have zero spacers.
    What are you guys running? How many bands? I think I'll toss two in and see how that goes.....
    Jan 2017
    let us know what you think when you do it, my monarch plus is being warranty at the moment so going to try a fox dpx
    My monarch seemed to bottom out maybe a little to much on the bigger jumps which are really not that big, I am thinking a spacer or two might fix that
    @Dave Mac - will do but it might be a bit. My current situation is that everything under the sun is designed for the DebonAir version of the Monarch so honestly I don't even know what spacers I need for this HV can. I got some delivered for "Monarch" but of course they are for the DebonAir and didn't fit my HV. I have since put my shock back together but will do some research, get some of the correct spacers, and give it a whirl....
  1. Replies: 4
    Last Post: 09-21-2017, 04:47 PM
  2. Fox volume spacers in a Monarch RT3
    By PhillipJ in forum Shocks and Suspension
    Last Post: 11-26-2015, 02:46 PM
  3. low volume conversion for monarch rt high volume.
    By RobinGB in forum Shocks and Suspension
    Last Post: 11-28-2012, 02:26 PM
  4. Volume! Volume! Volume! (BCOS on bad behavior)
    By GRAVELBIKE in forum Colorado - Front Range
    Last Post: 12-04-2011, 09:24 PM
  5. Fox RP23 High Volume vs. Rock Shox Monarch High Volume
    By beanfink in forum Clydesdales/Tall Riders
    Last Post: 04-22-2008, 10:46 AM
