Dropout chip bolt measurement- Mtbr.com
Results 1 to 11 of 11
    No Clue Crew
    Apr 2005
    This is a first. New '17 Phantom, lost a bolt out of the NDS dropout. Was six miles up National Trail at South Mountain, so had to ride it out. The exploded view on the Banshee site only calls it an M8 bolt. Anyone know the actual measurement?
    Just like a raindrop, I was born to fall.
    Braaap
    Reputation: DirtMerchantBicycles's Avatar
    May 2014
    8mmx12mm socket head cap bolt. You should be able to find one locally, if not, let me know.
    Dirt Merchant Bicycles
    Providing unrivaled support and unbeatable pricing on all cycling goods to riders near and far.
    No Clue Crew
    Apr 2005
    Yes, sir. 1.25 thread pitch. The diameter and pitch are easy. The 12mm length is impossible locally even at specialty fastener places.
    Reputation: geoya's Avatar
    Jun 2014
    Heads-up.
    Just discovered mine NDS bolts were loose on 2017 Phantom.
    Was messing with suspension and noticed my rear brake was loose. Almost lost the lower bolt.
    I trusted the locktite applied to the bolts from factory. Wrong, it did not really work, maybe just prevented me from loosing the bolt on the trail.
    Re-applied some good amount of fresh blue locktite, let's see how it holds.
    I have had these come loose on me on my phantom as well as on a Kona Honzo. A large thread pitch, a short bolt and lots of forces going through it make it hard for the limited thread contact to stay tight. Using the stronger red thread locker may be warranted.
    No Clue Crew
    Apr 2005
    Yep, I re-threadlocked mine with blue. Holding well so far.
    Reputation: JustMtnB44's Avatar
    Quote Originally Posted by Blatant View Post
    Really? Even Home Depot has them, albeit not zinc coated so they will get surface rust.
    Crown Bolt M8-1.2 x 12 mm. Internal Hex Socket Cap-Head Cap Screws (3-Pack)-08848 - The Home Depot
    I have not had any issues with these bolts loosening on my 2013 Spitfire, but if I remove them to adjust dropouts then I add blue Loctite when re-installing. The pre-applied Loctite really only works once.
    No Clue Crew
    Apr 2005
    You must have really awesome Home Depots. I checked all of them in my metro area, along with Lowes, Ace, etc. Nothing in stock, although yes you could order from the website.
    I never had issues with the old-style dropouts like you have.
    Jul 2013
    Quote Originally Posted by geoya View Post
    Heads-up.
    I too have noticed my axle and chip bolts coming loose on my '17 Prime a lot more than my '13 Prime. The axle especially, I find myself tightening it sometime a few times during a ride. Don't know if this is an issue with the dt swiss axles in general or the frame.
    No Clue Crew
    Apr 2005
    For me, the axle loosening is a symptom of the chip bolts loosening.
    Jun 2014
    btw, in the FAQ it's mentioned that one should tighten the axle first before tightening the dropout bolts during installation.
    I wonder why this is important, anyone have ideas, can it contribute to the likelihood of bolt loosening?
    FAQ – Banshee Bikes
  1. is this a chip in paint or a chip in the carbon?
    By greg_raleigh in forum General Discussion
    Last Post: 11-18-2016, 08:26 PM
  2. 2015 nimble 9 dropout axle pinch bolt
    By Samuryan in forum Canfield
    Last Post: 09-15-2016, 06:44 PM
  3. Replies: 1
    Last Post: 06-22-2014, 07:01 AM
  4. Pivot Mach 4 frame/dropout stripped @ hanger bolt - 2010
    By Rollin'in'Zona in forum Pivot Cycles
    Last Post: 10-30-2013, 05:43 PM
  5. 12mm dropout kit or Chip system
    By ericepark in forum Yeti
    Last Post: 11-21-2011, 08:49 AM
