Banshee Rune suspension play- Mtbr.com
Results 1 to 9 of 9
    Dec 2013
    So I swapped all the bearings on my frame and linkage this morning.
    There was no previous play in the suspension but the bearings were obviously done. Now that it is all back together there is slight up and down movement that I can't get out. Everything is torqued to spec....
    Anyone else ever have this problem?
    Checked the bushings of the shock? CC bushings tend to give up early...
    My Cane Creek pushings had play after ~10.000 vertical m of downhill *g*
    I haven't been so lucky like you... rode 2 Legends and 2 Runes and I had to change bushings really early on all of them.
    Quote Originally Posted by grazertourer View Post
    Lucky? 10.000 vertical Meters. That's like two days in a bike park or ~10 bike rides at home.
    Ha! Gotcha. I have to ride quite a bit around here to get 10.000 vertical meters. I think the bushings lasted ~ 10 rides, which would make up for like 3000 vertical meters.
    I fix choppers
    Reputation: HELLBELLY's Avatar
    I am accord with the above. It's most likely your shock bushings. If you have a Cane Creek definitely score their bushings from your dealer.
    I am now closing on two years with my Rune V2. I've replaced the bearings several times and changed out the shock bushings once. Despite the bike having mulitiple pivots it is pretty simple and inexpensive to maintain. The bearing location that takes the most abuse is the lower link frame pivot. If it is not torqued down properly it will wear out quickly. Checking this (and the other pivots) torque before each ride has helped out a ton.
    All in all it's a fantastic bike.
    "Everything popular is wrong." -Oscar Wilde
    Mr. Knowitall
    Reputation: hssp's Avatar
    My spit needs heavy torque on the linkage bolts, and develop play after some rides...
    Reputation: dirtrider76's Avatar
    Sep 2012
    Man I ate through Fox bushings pretty fast and they always gave me play. My Rune has seen 2 seasons of riding with no bearing changes. I have them and was going to do them last season but I checked them all and they spun free. I'm really good at taking care of my bike though.
    I like to fart when I'm in front of you on a climb:skep:
  1. Banshee rune v2 question
    By rschroeder714 in forum Banshee Bikes
    Last Post: 07-18-2013, 01:09 PM
  2. Banshee Rune 2013
    By rideit in forum 27.5
    Last Post: 10-27-2012, 11:03 AM
  3. Banshee Rune and Fox 40
    By Hydesg in forum Banshee Bikes
    Last Post: 08-04-2012, 08:36 PM
  4. 2012 Banshee Rune...When
    By Birdman-X in forum Banshee Bikes
    Last Post: 05-05-2012, 02:58 AM
  5. Banshee Rune Suspension Play?
    By darkslide18 in forum Banshee Bikes
    Last Post: 10-30-2011, 11:53 PM
