Banshee 2014 rune - hope brake adaptor???- Mtbr.com
    Jun 2014
    Hi All
    just asking around to see if anyone is running hope E4 brakes on their rune. Im just about to purchase a pair but would like to know which Hope brake adaptor mount i need for the rear if i was running a 180mm rotor.
    I own a 2014 rune v2, hope someone can help
    cheers in advance
    The rune has an IS mount for the rear. Ive got hope brakes and am using 180mm rotors, so this is the adapter Im using: https://www.jensonusa.com/Shimano-18...-Brake-Adaptor
    fwiw the shimano one works fine with my hope brakes.
    Jun 2014
    Thanks eeyore, that's exactly what i was hoping to hear. I have a shimano set up all ready so ill just buy the brake itself. Do you know if the hope brakes work with icetech rotors too? i plan to get some hope floating rotors but my ice tech still have plenty of life left in them!
    I want to say the ice tech rotors will be just fine, but I have no personal experience as such. I would make sure the pad material that you were using with the shimano brakes is similar to the hope brakes. sometimes rotors dont play nice when you switch from resin to metal...might be worth it to just use new rotors....
  1. Banshee Rune V2 2014 lower link wearing out
    By nor_bak in forum Banshee Bikes
    Last Post: 09-23-2018, 12:21 PM
  2. 2014 - Banshee Rune - play in frame
    By metalheadmarsden in forum Banshee Bikes
    Last Post: 07-05-2016, 10:40 AM
  3. Replies: 0
    Last Post: 04-06-2012, 08:19 AM
  4. Banshee Rune rear brake vibration
    By bigmike9699 in forum Banshee Bikes
    Last Post: 04-01-2011, 01:49 PM
  5. Replies: 2
    Last Post: 04-29-2004, 07:08 AM
