B+ spitfire or rune?- Mtbr.com
Results 1 to 3 of 3
    Hi,was wondering if anybody on this forum has tried putting 26+ tires on a Rune or Spitfire? I own both and would like to try it out but not sure it would work. I see surly makes the dirt wizard in 26x3 size but don't see to many other 26+ tires out there.
    Will these bike take any of the 27+ tires available out there?
    So anybody riding 26+/27+ tires on there Banshees?
    Also-does the 29er phantom or primes have longer dropouts than the rune/spitfire 27.5 ones? They interchangeable with rune/spitfire?
    Thanks gang!
    Chris
    Hard funkinī Kraut
    Reputation: NoStyle's Avatar
    May 2005
    I havenīt tried it for myself, but I think you can run 26+ tires (up to 2.7/2.8) in the Spitfire with the short dropouts. The inner width of the chain/seat-stay is 74mm, so tires with max. 70/72mm width should work. Same for B+ tires in the 650B-dropouts.
    The Phantom and Prime can of course take the 650B-dropouts, wich lengthen the chain-stays to fit 29+ tires with max. 70/72mm width.
    Take some reading here ...
    Hereīs a pic from a german Rune-Rider, with 650B+ WTB Trailblazers 2.8, 650B-dropouts:
    Reputation: LyNx's Avatar
    As NS said, the drop outs are inter-changeable between the Rune, Spitty, Prime & Phantom so the same way you can use the 650B ones on a Rune or Spitty to accept the bigger 650B tyres, you can do the same with the 29ers to accept the 29+ tyres. Width wise all the chainstays will easily clear the 2.8" PLUS tyres, things might become a bit tight if you go 3">, especially when you take tyre stretch into account - my Chronicle stretched a lot over a couple months.
    Quote Originally Posted by Harold
    You're doing mtbr wrong, you're supposed to get increasingly offended by the implications that you're doing ANYTHING wrong.
  1. V2 Dilemma - Spitfire or Rune??
    By dirtysurfer in forum Banshee Bikes
    Last Post: 04-03-2015, 10:27 AM
  2. rune vs spitfire
    By mrsa101 in forum Banshee Bikes
    Last Post: 01-23-2014, 12:22 PM
  3. Rune/Spitfire - Clearance with 1x10 and 30T or 28T?
    By in the trees in forum Banshee Bikes
    Last Post: 09-28-2013, 09:27 AM
  4. Where are the bearings on the new rune and spitfire?
    By dansMTB in forum Banshee Bikes
    Last Post: 01-20-2013, 05:34 PM
  5. Help me decide - Rune or Spitfire
    By uzurpator in forum Banshee Bikes
    Last Post: 04-26-2011, 04:01 PM
