2015 Banshee Spitfire V2 with RACEFACE ARC 30- Mtbr.com
Results 1 to 6 of 6
    Oct 2016
    Has anyone build this wheel before Raceface Arc 30 Pair with Hans Dampf 2.35 tire on a 2015 Spitfire V2 before? Does it fit the clearence ?
    Apr 2016
    Quote Originally Posted by darkcrow View Post
    I run WTB assym i35 with nobby nic 2.8 or DHR II 2.8 in the rear. Its tight but it fits. You'll be fine
    Oct 2016
    That's great. Thanks for the info.
    Reputation: RS VR6's Avatar
    Quote Originally Posted by Endless Trails View Post
    Whoa...you can fit a 2.8 in the back of a Spitfire? I read somewhere that it measures out to a 2.6. I'm running a 2.35 Nobby Nic on some i29 rims on the rear now. Looks like there is a good amount of room.
    Oct 2016
    Anyone could share pictures of the rear wheel tire between the frame. How close is the tire against the frame?
    Apr 2016
    Quote Originally Posted by RS VR6 View Post
    On the DHR II the carcass is 66mm / 2.6" and the side knobs are 69 mm/ 2.7". But it's very new. Out of the box it was only 63 mm wide so I'm not sure if it'll stretch a bit more. I've done about 1300 km since january when I built up the bike, I got some very light rubbing marks in the anodisation on the left chainstay, probably from the Nobby Nic I used to run being a bit wobbly. Like I said, its itght but it works. A 2.6 would probably be better though.
    Endless Trails Outdoor Equipment - Waterproof bikepacking bags and outdoor equipment
  1. Banshee Spitfire
    By skidad in forum 27.5
    Last Post: 03-08-2017, 10:03 AM
  2. Bronson vs. Banshee Spitfire V2
    By zuuds in forum Santa Cruz
    Last Post: 08-08-2014, 06:19 AM
  3. Banshee Spitfire to 08 Reign X: Would you do it?
    By cskolnick in forum All Mountain
    Last Post: 07-20-2011, 01:44 PM
  4. Banshee Spitfire???
    By Warp in forum Banshee Bikes
    Last Post: 05-14-2011, 11:57 AM
  5. 2011 Banshee Spitfire.
    By Cycle64 in forum Banshee Bikes
    Last Post: 04-02-2011, 04:30 AM
