Results 1 to 8 of 8
    May 2010
    Tube/Tire suggestions
    So I keep getting flats, I've had my bike for about 3 weeks now and have had a total of 4 flats. 1 in front 3 in rear.
    Please recommend me a good tube/tire combo ( 29er )
    No tubes is my recommendation. Either Stan's kit or Ghetto tubeless.
    I'm still trying to figure out what rear tire I like, but I'm pretty happy with the Specialized Purgatory 29x2.4 on the front.
    May 2010
    Word, I didn't know this was possible. I'm definatly going to buy or make my own kit and do this ( and get better tires ).
    Thanks man
    slow and whiney
    Feb 2010
    Reads like a commercial.
    rock crusher
    Wider rims will help as well. When I moved up to 28mm rims, my flat rate went from one every other ride to one every 3 months. Also, Slime in your tubes will help dramatically.
    That being said, tubeless makes a lot of sense, but will require more maint. than what I mentioned above.
    Feb 2010
    Tubeless, no doubt about it. I run a Saguaro Geax in back and a Kenda Nevegal up front (both 29'er). No flats (knock on wood for the no-jinx here) for 6+ months around SoMo, Hawes, MMP, etc...
    I also run ghetto tubless. I havent had a flat in 2 years and have popped the tire off the bead to check/add sealant and give it a blast of air and all is well. This by far is not a hassle or messy and so far for me has been dang near free of maint.
    Quote Originally Posted by AZ_Wook
    +1 on the Saguaro. On my rig I run the Saguaro 2.2 up front and the Geax AKA 2.2 outback. Both tubeless, love them!
