Results 1 to 2 of 2
Thread: Technical help
    Technical help
    Guys/Gals,
    I have a 2000 Specialized stumpjumper comp...........mostly XT parts.
    Anyways, I broke my rear derailleur, i actually lost the upper pulley on the derailleur. Its 9 years old, so not that big of a deal, but when I called the bike shop and asked if it were a long/short cage or a top/side pull, they told me it was a regular XT der.
    So, what I'm asking is, is there such a thing as a regular derailleur and does it matter if i can't find that part(2-3 weeks to special order one), should i just buy a new derailleur and which one.
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    Are you running 3 rings? If so, you'll want a long cage der. The rear der's are pretty standard (staying with Shimano) so you can either go with XT or even SLX if you want to save a bit of $. On the other hand, you can just replace that pulley and keep using what you have. Any bike shop will have some old busted der's or parts laying around. Easy fix
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
