Results 1 to 25 of 25
Thread: Squeaky brakes
    Reputation: Casual Observer's Avatar
    Squeaky brakes
    Anybody have any suggestions for squeaky disc brakes? Brakes seem to be adjusted correctly, and I did scuff the rotor with sandpaper. Any other suggestions, or is this an indication I need new pads?
    Nobody gives a s#$t you singlespeed.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Have you cleaned the rotor ? How thick are your brake pads ?
    Quote Originally Posted by AZ.MTNS
    THAT I haven't done, and didn't even think about it until you just posted this. Just clean with alcohol, yes?
    The pads are about 1/16" thick.
    Scuff your pads not the rotor. Your pads are probably glazed. Sand you pads and clean the rotor with some brake cleaning spray. Just don't get it on your wheels or frame it may eat the paint or anodizing!
    Reputation: brianc's Avatar
    chain lube works best for cleaning rotors.
    Squeeky.....you should have heard the choir of disc brakes as 6 of us decended a snow covered ridge in Santa Fe last weekend. it was heavinly. =)
    b
    Any chance you have Avid brakes? If so, throw them out.
    Quote Originally Posted by crispy
    Eventually I will learn my lesson.
    Quote Originally Posted by brianc
    Can I use bearing grease instead?
    My brakes in general have a small squeak. In the last couple rides however, it's been rather annoying..
    Reputation: Evil Patrick's Avatar
    Sep 2004
    Things may be misalligned.
    Have you tried feng shui?
    -- Evil Patrick
    Some of my Music
    My Videos
    The trail...shall set you free.
    Quote Originally Posted by Evil Patrick
    A long time ago, but my girlfriend said it made her feel cheap, so we went back to Missionary.
    Quote Originally Posted by skinny-tire
    given our dry climate I would advise against it. the sand and grit that it will attract will defeat the intended purpous.
    b
    all the brakes have their own set of problems, ----I run the advids and there are good.--( I have them on 3 bikes with no noise )
    I will glass bead my rotors and the pads to de glaze them , then they seat in and are fine .
    I have found the advid organic pad with the aluminum backing works the best for me , along with the clean sweep 3 rotor.------( the cheep aftermarket pads do not work at all ---you will play hell to try and make them quiet )
    I run an 8" ft and a 7" rear , ---things work really well , once I get my pads burnished in they will run silent untill they are gone .
    I've heard that the organic pads help with the squeaking. But you have to replace them more frequently.
    Ouch, I am hot!
    Reputation: Dirdir's Avatar
    ...I did scuff the rotor with sandpaper
    My god man!
    I AM JUST A JERK
    I have not noticed hardly any difference in wear ( ----of course I could not get the metalic or cermic pads in any of the brake brands to ever shut up , so I never ran them out -------and they were grabby and screwed with my technical slow speed balance and ridability.
    ( as almost all the cermic metal pads do on all the brakes )
    Once you get used to the smooth progressive feel of the organic pad , and their silent operation you will not ever go back.
    I also see so many guys out here with way way to small of brakes on the bikes , -------this of course will overheat the things quickly ,
    there are so many things to really getting brakes dialed in on a bike , ---the correct 5.1 dot fluid ( for avid ) really gets rid of heat better and will withstand more heat.
    Getting the brakes blead correctly ,
    the correct alignment , the correct clearance on each side of pad.
    Getting the new pad burnished into the rotor .
    any of the brakes on the market all need to be dialed in and worked with to get them working correctly.
    Rhino
    Reputation: urbanseeds's Avatar
    disc brake squeal is the new SS bell
    Reputation: ECEGatorTuro's Avatar
    Are your Avid's squeaky or is it a howl that sounds like a honking goose and vibrates the whole frame (and seat post)? If it's the howling, then your frame is resonanting with the caliper vibration. I had this problem every since I got my bike early this summer and the cheapest fix I found was to dampen the vibration on the frame by wrapping an old tube around part of the frame near the offending rear caliper and zip tying it in place. Worked like a charm and now my Avid's are completely silent and it didn't cost me anything.
    Ahh, that would be the infamous Avid turkey gobble. For about 2 weeks, my favorite thing to do on long rides was come up with new ways to describe that sound. My best one was: It sounds like a hillbilly raping a cow.
    Meatbomb
    Reputation: Phillbo's Avatar
    How many cows did you have to rape to refine the sound ?
    singletrack bound
    Reputation: Tone No Balone's Avatar
    Dec 2004
    must have been a long hot summer in Zona........
    Reputation: hikerdave's Avatar
    Mar 2006
    Quote Originally Posted by urbanseeds
    I have a 6 inch rotor on the back and 7 inch on the front. In wet weather the two brakes squeal in a minor chord that sounds just like a train.
    "Thank you, God, for letting me have another day"
    The Milagro Beanfield War
    That cow was asking for it. You shoulda seen the little skirt she was wearing.
    Fragile - must be Italian
    Reputation: dgangi's Avatar
    Change to organic pads. Problem solved.
    Metallic pads might last longer, but they are prone to making lots of noise on ANY brand of brakeset. Plus organic pads just "feel" better.
    Thx...Doug
    Slow but unsteady
    Reputation: Mule Ears's Avatar
    Idea! Countersink rotor holes
    Lightly countersink the holes in the rotor, just enough to chamfer the sharp edges. You don't even need to use a drill; just twist the countersink bit with your fingers using light pressure. Do both sides. I've used this trick on three sets of brakes and it has reduced or eliminated brake noises that weren't cured by the usual fixes (cleaning, adjusting, etc.).
    My other ride is your mom
    Reputation: Maadjurguer's Avatar
    Quote Originally Posted by Mule Ears
    Now that's one tip I have yet to see or try....too bad....since I got rid of my J7's for SLX's....I've had no Turkey on my ride.
