Thread: SID Tool Needed
    I'm with stupid -------->
    SID Tool Needed
    Anybody local (Phoenix area) have a SID Dual Air Upper Tube Removal Tool they are no longer using available for purchase?
    http://www.amazon.com/RockShox-Dual-.../dp/B001CJVHKU
    I need to replace some seals in an old fork and really hate the idea of dishing out 30+ bucks for a tool on a fork that's life is so limited... so I figured I would throw it out here and see if anybody has one they no longer need. Thanks.
    Nobody? Or any ideas how to ghetto rig it? I really hate the idea of paying 30 dollars for a threaded nut....
    May I should just replace the thing with a 26 inch Reba.....
    Quote Originally Posted by jdpowers
    1. Take a bolt where the head will fit into the hex opening on the cartridge.
    2. Spin on two (threaded) nuts and jam them very tightly against one another.
    3. Put the head of the bolt in the hex opening and use a wrench to turn the tool.
    You might be able to find a long nut in a hardware store to do the same thing, but you might be limited to a SAE sized bolt.
    Dec 2008
    i have one of those tools you need.
