Results 1 to 7 of 7
Thread: Sans Tubes
    Alive and Lurkin'
    Reputation: Jibro's Avatar
    Sans Tubes
    I'm finally going to make the switch to tubeless with some home-brew tubeless mixture (swamp sauce more than likely). I have some 823s being built for the new ride. I also have few WTB Motoraptor 2.4 laying around that I would like to try. Anyone have any luck using this tire in a tubeless set up? A 2.5 is what the frame says is the max tire size. Other than Continentals (most of which I don't care for), what is a good 2.5 that works well as a tubeless that folks run around here?
    Pumpin & Pimpin
    powered by bacon
    Reputation: helidave's Avatar
    the Intense DH tires work great tubeless and they're only like $16 on Jenson
    Alive and Lurkin'
    Nice call $15 . The folding bead works well for tubeless set up?
    Pumpin & Pimpin
    powered by bacon
    never had any problems with them or the 2.35 version
    Alive and Lurkin'
    Just ordered a pair.
    Thx Again!
    Pumpin & Pimpin
    Swamp Thaang Groupie
    Reputation: abcnorte's Avatar
    If the bead is snug on the rim they will work. I have had the best out come with wire bead tires. Swamp sauce ghetto is the way to go
    Let'er Buck
    Reputation: kdimon's Avatar
    I just decieded to make the jump to tubeless as well, I did gorrilla tape on the rim and 2.4 mutano on front and 2.2 wolverine in the back, but I went with the new tcs line from wtb in both tires and so far its great. I only have a few rides on them but love it and they sealed up extremely easy, I did use a compressor but think a floor pump would have worked even. Good luck
    "Powder River, Let 'er Buck"
