Results 1 to 8 of 8
    Rockshox charger damper servicing recommendations
    New-to-me non-boost 27.5 fork. The damper is dead, no damping compression or rebound. Some wetness around the rebound lever.
    1. What are the chances I need a new damper?
    2. Who services these near Ahwatukee (and KNOWS what they are doing)?
    Michael
    old guy
    PMP,TAN,LAUNDRY
    Reputation: azdog's Avatar
    Stillwell Suspension if it is indeed the damper that needs service. Otherwise, Morgan at Rage should be able to diagnose.
    Bender to AZDog: I'm not the best person to give advice on not riding!
    Reputation: rockman's Avatar
    Pretty easy to do yourself but you will need a basic service kit, especially if the leak is from a torn bladder. If it's never been serviced you might need to replace it anyway. Plus, fluids. With the markup on the seals and service kit and fluids combined with labor and you might just consider plopping a new damper in for a little over $200.
    Reputation: In2falling's Avatar
    Jan 2005
    Quote Originally Posted by masterp2 View Post
    Rebuilding/full servicing Pikes are fairly simple and straight forward, have done 3 times now and not really that hard.
    Looking at about $45 for rebuild kit, another $30 for bleed kit, few tools (small ring pliers) and few hours of time. Rockshox has great step by step guides and also lots of how-too youtube vids, if you attempt to do it yourself.
    Anyone have the service kit part number? Mine is a 2016 130-160 non-boost.
    Michael
    old guy
    Thank you for the comments. Might have someone down near Ahwatukee do it if there are any recs.
    Michael
    old guy
    You didn't say whether it was a Pike or Lyrik? Dual position air? This is the kit for a Pike. https://www.jensonusa.com/Rockshox-P...l-Service-Kits
    You'll also need a bleed kit: https://www.jensonusa.com/Rockshox-C...mper-Bleed-Kit
    Nice write-up on doing the deed: How to Bleed RockShox Charger Damper | Epic Bleed Solutions
    Reputation: azjonboy's Avatar
    Keith at Landis on Warner is a solid wrench. Has done multiple fork repairs / rebuilds for me over the last 20 years.
    If you're lucky enough to be in the mountains,
    you're lucky enough.
  1. Long Term Report: Rockshox Pike Charger Damper
    By bing! in forum Shocks and Suspension
    Last Post: 08-29-2018, 03:23 PM
  2. Question on Pike Charger Damper Bleeding/Servicing
    By jaks in forum Shocks and Suspension
    Last Post: 03-26-2018, 10:49 AM
  3. Replies: 6
    Last Post: 05-01-2017, 09:04 AM
  4. Replies: 1
    Last Post: 11-19-2015, 02:52 AM
  5. rockshox charger damper rebuild?
    By terrible in forum Shocks and Suspension
    Last Post: 04-29-2015, 06:57 PM
Members who have read this thread: 36
