old tires, Stans, rough bead, re-usable?- Mtbr.com
Results 1 to 6 of 6
    I pulled a set of 2.5 2-ply Maxxis Minions off my wheels (Mavic SXs), which had been run tubeless with Stans for quite some time.
    Beads are pretty rough... Stans deteriorated them possibly.
    I now need to put these tires back on.
    In your experience, are these rough beads going to reseat and hold air (Stansd) or am I wasting my time?
    The tires still held air like a champ when I removed them last month.
    And, for the record, if you are going to wail a 7 coil bike on south mountain, single ply Larsens are a very poor choice of rubber... even with Stans on board.
    My bike, Slayer 70
    Reputation: GR1822's Avatar
    IMHO the only way to know it to try it out. If it held before why wouldn't it hold now?
    parenting for gnarness
    Reputation: chollaball's Avatar
    Apr 2005
    anything is possible, but sounds like you may be in for an uphill battle. if they are wire beads and bent up, you are screwed. you could try mounting them without spunk only using soapy water to get an idea of if they will seat before you make a mess.
    YES to Scottsdale Prop 420
    Our Preserve, Our Taxes, Our Vote
    Reputation: woahey's Avatar
    When I had to seat old, used beads, I used the wife's green scrub pad from the kitchen sink to clean 'em up a little bit. Before cleaning the bead they didn't want to seat but after they did great.
    The secret to mountain biking is pretty simple. The slower you go the more likely it is youll crash.
    - Julie Furtado
    dirt visionary
    Reputation: clockwork's Avatar
    Just clean them up a bit and add a tad bit more stans I have had no issues and have pulled some nasty suckers that even showed rust.
    Life should NOT be a journey to the grave with the intention of
    arriving safely in an attractive and well preserved body.
    well, I used a nylon brush and some simple green... then washed the residue away with clean water.
    I seated them last night and they actually held air without Stans... although rather low pressure this morning.
    I'll add Stans today and call it a done deal.
    Thanks all.
    My bike, Slayer 70
  1. Help with leaking bead with Stans
    By racer502 in forum Wheels and Tires
    Last Post: 11-30-2008, 08:15 AM
  2. Are these tires still usable?
    By boyRacer in forum Wheels and Tires
    Last Post: 09-29-2004, 04:54 PM
  3. Wire bead vs. Kevlar Bead tires?
    By cdloental78 in forum Beginner's Corner
    Last Post: 08-04-2004, 11:13 PM
  4. I can't get my bead to seat (UST/STANS)!
    By rideit in forum General Discussion
    Last Post: 02-27-2004, 08:35 AM
