New whitewalls for the singlespeed- Mtbr.com
Results 1 to 6 of 6
    Fragile - must be Italian
    Reputation: dgangi's Avatar
    Late last year I posted a message about how I cracked the rear rim on my Bianchi Rita. I have since replaced the silver Velocity wheels with some white Stans Flows (same hubs...just rebuilt with new rims).
    I realized that I never put up any photos of the result. Well, here it is...
    Thx...Doug
    Attached Thumbnails Attached Thumbnails New whitewalls for the singlespeed-dscf0378.jpg
    Rhino
    Reputation: urbanseeds's Avatar
    Which model Velocity rim did you crack?
    Quote Originally Posted by urbanseeds
    Velocity Blunt. Split it right at the seam/weld when I nailed a rock and pinch flatted. I opted to go with Stans Flows as a replacement since they work 10x better for tubeless applications.
    Thx...Doug
    Ride 'Til Your Knees Hurt
    Reputation: cycljunkie's Avatar
    The white rims do look nice...
    Rhino
    Quote Originally Posted by dgangi
    Thx...Doug
    Curious as I am building up some blunt race wheels. I'm a luddite and still run tubes...and sans suspension, so hopefully they hold up. Good job on the hill today. -rhino
    The Blunts are crazy wide inside (~24mm), so I *really* liked how my tires filled out when mounted to them. What I didn't like about the Blunts was that it was a *beatch* to convert to tubeless, as they have a huge channel to fill before you can put the rim tape into them. Plus some of my favorite tires, such as the Panaracer Rampage, didn't fit very tight.
    Otherwise, I really liked the Blunts until I cracked them. I have a feeling that was more of a case of bad luck than anything else.
    Thx...Dug
