Fox Fork Fluid - Ahwatukee Area- Mtbr.com
Results 1 to 9 of 9
    Anyone have a good source of where to pickup a can? (and also not get charged an arm+leg) such as a motorcycle shop, etc?
    -- should clarify I am looking for 10wt green
    Try South Mountain Cycles at 480-706-0858 they have been good to me. Their at E Ray Rd & S Mountain Pkwy
    jddist
    I either get it from cactus or order directly from fox.
    It's a Sledgehammer.
    I got some fork fluid from Kawasaki superstore. The oil weight is what matters, not the brand.
    Reputation: cstem's Avatar
    Quote Originally Posted by jperson
    Actually that is a real common misperception due to what we have all been taught by instructors at MMI, UTI, high school and TV commercials. For a real answer from an engineer go here http://www.peterverdonedesigns.com/lowspeed.htm and prepare to have your eyes bleed with boredom. I thought the same exact thing for years. BTW- this guys website is kind of cool in a Sheldon Brown kind of way.
    here is some more specific right to Fox http://www.cyclingcentralva.org/geninfo.html By that info you could save some coin and buy Torco which should be readily available at many Moto shops.
    Vassago Cycles, Shadetree Bikes, Flat Tire Bikes, Galfer Brakes USA
    Reputation: 'size's Avatar
    the cSt is what matters, not the weight.
    Ended up finding it at SMC - couple other shops I had called were out (go figure I didn't try SMC)
    Now off to hack my DHX to make a bit stiffer for this clydes!
    Eroding into the trail
    Reputation: DustyBones's Avatar
    Jun 2010
    Quote Originally Posted by cstem
    A treasure trove!
    Thanks for the great info - very enlightening!
    I used to use Motul synthetic oil for my motorcycle forks and engine oil; I always liked their products. Interesting how much variance there is between oils!
    You are all right, the cst matters sure. Good info on those posts.
    I like knowing what brand the oils really are. Torco medium for me next time.
    Although I am currently using golden spectro and it feels as good as
    new after 5 years..
