Fork trade: My coil, your air- Mtbr.com
Results 1 to 17 of 17
    No Clue Crew
    Apr 2005
    Hey, all. I'm looking to move to an air fork on my pedal bike and away from the coil I'm running up front. Nothing wrong with it, just looking to drop a touch of weight and better match my RP23.
    Rockshox Lyric coil, 160mm, 20mm thru, 1 1/8 steerer cut just a hair under 8 inches. Rebound, high- and low-speed compression, all three coils (light, medium, heavy). White lowers with typical rash; stanchions are clean.
    What I want to trade for: 160mm only (no 150s or 170s) Lyric solo air or Fox Float, 20mm thru, 1 1/8 steerer (no tapers) minimum 8 inches of steerer.
    Feel free to PM or e-mail at [email protected]
    PMP,TAN,LAUNDRY
    Reputation: azdog's Avatar
    Blatant, I'm out with injury right now as you probably know but if you want to try out my 160 float you're definitely welcome to. It's a 2010 fox float. What's the overall weight on the lyrik?
    Bender to AZDog: I'm not the best person to give advice on not riding!
    Quote Originally Posted by Blatant View Post
    Just convert your Lyric to a solo air and there you go , that fork can be what ever you want it to be .
    Shovel Ready
    Reputation: Cycle64's Avatar
    170 can be made a 160 with a spacer removal.
    Correction. I think you add a 10mm spacer.
    Currently at Mayo Clinic being tested for a kidney transplant. Donors welcome. :)
    PMP,TAN,LAUNDRY
    Quote Originally Posted by Cycle64 View Post
    How did you make your lyrik into a 180 travel fork again???
    Quote Originally Posted by azdog View Post
    Yep , these Lyrik forks are very nice to change travel or to valve and make work just the way you want them to.
    You can remove a factory spacer to make them 170 and with alittle machining you can make them 180s as well.
    Actually any fork or shock can have the stroke and travel altered to suit to a point , and most forks can be changed from spring to air and so on .
    Your better off starting with new components and working with them untill you get them dialed for you
    On my Enduro I have changed my e-150 fork to 165 mm travel , I have changed the rear to 160 , I changed the 67 degree head tube angle to 66 and brought the valving around to where it works for me, now the bike is light and rides like a big bike
    Shovel Ready
    Skills.
    ******ed or Branded??
    Reputation: doodooboi's Avatar
    Lack of Skills.
    FTFY
    Shovel Ready
    Quote Originally Posted by doodooboi View Post
    FTFY
    Was speaking of wrenching not riding. So no need to fix what was typed. Thanks for playing though.
    Wasn't talking about your riding skills.
    Shovel Ready
    Just because I don't care for cheap bolts the bike industry uses. Is not a reflection on my ability to turn a wrench. Hell I was turning wrenches on cars back when you were filling a diaper.
    "No Clue Crew"
    Reputation: Grave9's Avatar
    Spam!!!!!!!
    True! But I probably knew how to fill my diaper with 170mm of poo than 180mm!!!
    Still a fail on your part.
    Shovel Ready
    I'm sure you had many a blowouts in your days. Heck you may still have them.
    Now quit hijacking this very important spam thread.
    "No Clue Crew"
    S.p.a.m.
    Again true but your now back at that stage in life sorry to break it to ya gramps!
    Shovel Ready
    again true but your now back at that stage in life sorry to break it to ya gramps!
    ftw.
