Results 1 to 9 of 9
    Dooosh!
    Reputation: BRA DOG's Avatar
    9 speed cassettes
    Which do you prefer? 11/32 or 11/34?
    Quote Originally Posted by BRA DOG
    11-34-------even tho I do not use the 34 when in the granny ring ------- But I do use the 34 when on the middle ring for my default climbing gear .
    I'm with stupid -------->
    32... allows me to use more gear combs while running a med cage derailleur.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    On my 29er I prefer the 12-27.
    On my 26ers I prefer 11-32.
    Reputation: BIGHORN LEW's Avatar
    11-34, I NEED all the help i can get with my bike weighing 37 pounds!!
    RAM speed: UP, UP, and away....!
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    34 , I'm weak .
    Dec 2004
    11/34 all the way...you will climb faster on those gnarly hills and recover quicker!
    11-34 for the Phoenix area. When I lived in Utah and rode in the mountains, I liked the 11-32, because 22/34 was just too small to really pedal up the steep loose stuff without spinning out. Since I moved to Phoenix, I like the 11-34 because I can pretty much stay in the middle ring (32) up front all the time, and have little need for the 22 ring. With a 11-34 rear, and a 32 front, you can pretty much go 1x9 here in Phoenix (unless you are an xc racer type and need the 44/46 big ring).
    "Doing the right thing" is like water. It's good for all living things,and flows without thinking about where it's going.
    Also, the gear ratios are different between an 11-32 and an 11-34:
    Sram pg990:
    (11-32) 11-12-14-16-18-21-24-28-32 - 275 grams
    (11-34) 11-13-15-17-20-23-26-30-34 - 305 grams
    Shimano XT is the same ratio, not sure about the weight.
    So if you look at just the lowest 5 gears, you have an even difference of 2 gears throughout the range;
    18-21-24-28-32 vs. 20-23-26-30-34
    In the higher gears, with the 34 rear, you have easier gears all the way through the range with a slightly bigger difference in gearing in the 11-20 range. With the 32 rear, you have faster gears all the way through, and a bit tighter gearing in the 11-18 range.
