I'm doing an ITT of the OP, should i use maxxis or kenda, what size, and can anyone recommend a good sealant. The race is coming up next weekend I need to be ready!
You will need extra sealant for Kenda to plug the porus sidewalls.....plan accordingly or buy the Kenda tubeless specific tire!!!! By the way.....don't forget to get the right gatoraide for your 29'r!!!!
24HitOP ITT pro-tip: install the tires backwards & ride the course in the CW direction. This works for ANY tire combo & size!! You'll be amazed how the tires grip the corners & climb the rock drop. I'd be surprised if you don't consistently pull 1:02:00 lap times. You're welcome.
