XL/XXL helmet for irregular noggin with a shunt?- Mtbr.com
Results 1 to 23 of 23
    So I'm just getting back into riding after a 5+ year hiatus and I need a good helmet. Unfortunately when I used to do a lot of trail riding in my younger years I was poor, and helmets for a head as big as mine were hard to find. Now that I'm older, wiser and can afford it I'm going to quit being an idiot and get a helmet. However, the issue of my head size still makes selection difficult. A good fit is also complicated by the fact that I have a shunt on the side of my head, so I've basically got a big knob on the side.
    I'm looking for a helmet that comes in 62cm+, so XL or XXL with good adjustability and good comfort, that isn't going to break the bank. The LBS came up with the Laser O2 in XXL, and because of an "in" I can get it for a discount, about 20% off. Is this a good comfortable helmet with good adjustability, and what are some other options for someone in my predicament that wont break the bank? My actual hat size is 7 7/8 - 8 btw.
    Dec 2011
    I have the same size head as you. Only helmet I have found acceptable is the Bern xxl zipmold model. It's a little hot, being skater-style, but it also provides more protection.
    My fiance has an even bigger head, and I had to get her the Bern XXXL, which only comes in a multi-impact version for skaters, but better than nothing.
    Rockin'. Thanks for the info. This is actually the first post I've put up that has actually gotten a reply. lol Since I posted this I actually made a decision and had the LBS order me the Lazer O2 XXL for me. At 63CM the options were definitely limited. This seemed like a good helmet and the few reviews I was able to find were favorable. Whether or not it's going to give me issues with the giant knob on the side of my head (shunt) remains to be seen, however if I do have an issue with it, it'll probably be the same with any other helmet. I'll try to remember to atleast post some feedback on the helmet once I've had the chance to ride with it for a few days.
    Reputation: tpc1's Avatar
    Jun 2010
    I have the same problem, Big goofy shaped head. I ended up getting a Kali. They were great to deal with and the helmet is very comfortable.
    Will Miss You Tessa
    RIP Wild Bill
    10-4. The order for the Lazer went out on Thursday or Friday so hopefully it'll be here mid-week. I'll follow-up with opinions etc. when it gets here.
    Same weird shaped head here. I am currently using a bell sequence. It sort of fits. I'm actually looking to order the Bern Brentwood. Also going to try the new Giro feature. I'll post feedback when I get the helmets.
    Reputation: lazymuf's Avatar
    Jan 2011
    Anyone knoes where can i get a Kali helmet XL online?
    I saw a couple on jensonusa.com and cambriabikes
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    I have been helmet shopping for a bit to replace my well worn 2007 model Giro Xen (the most comfortable helmet I have ever worn). I was open to getting another Xen, but wanted to check out some of the new offerings like the Fox Striker, Giro Xar, POC Trabec, and others. I have a fairly good sized jug, so I am always searching for the larger model, though there's not much that can be done to ever make me look stylish (just think of 'Chunk' on a MTB).
    Never did find a Striker to try on, and I just couldn't take a chance without trying one on first. I tried several from Giro, some from Trek (Bontrager), Cannondale and Specialized. I didn't care that much for the Xar, but would have been vey happy with a Xen. After trying on several more exensive models from Specialized, I saw a tag that said XL, followed by that dreaded word. . . . . "Universal". I have become a bit jaded about considering cheap helmets because I have always found them to be uncomfortable, not to mention a little fugly, but I tried one on just for S&G, and was very surprised to find it VERY comfortable. And it wasn't too heinous looking on top of my bloated dome ;~)
    The MAX s not even listed on the Specialized site as a MTB helmet, it's listed as a "recreational helmet" with an MSRP of $40, but it comes with a dial type adjuster and felt better to me than anything else I have owned or tried on other than my trusty Xen. I thought 'what the heck' and took a chance on it and it has passed muster on the trail quite nicely so far.
    The size range is listed as 56cm to 64cm (size 7 to size 8). I am right around a 7-3/4 hat size, so it's not maxed out by any means. At any rate it seems to be a comfortable helmet for those on a small budget with a big noggin.
    Hi Guys,
    I thought I'd consolidate some info for future searchers re: XL and XXL helmets. In general, if your head is over 62cm (7 3/4 hat size), you're in XXL or above territory. Most brands XL helmets top out around 62cm. Here's a list of XL/XXL helmets that we happen to stock (hopefully other dealers can add other brands/models to this thread). Alphabetical order, 2011/2012 Versions:
    1. Bell XLV, size UXL - up to 65cm
    2. Bern helmets with ZipMold liner, size XXL - up to 62cm
    3. Bern helmets with Broc liner, size 3XL - up to 63.5cm (not CPSC rated)
    4. Fox Flux, size LXL - up to 63cm
    5. Fox Striker, size LXL - up to 63cm
    6. Giro Venti, size UXL - up to 65cm
    7. Giro Xen/Xar, size L - up to 63cm
    8. Kali Aatma, size XXL - up to 65cm
    9. Louis Garneau Arcterus, size XL - up to 65cm
    9. POC Trabec, size XL/XXL - up to 62cm
    Plus, here's some info on translating sizes back and forth:
    Centimeters, Inches, Hat Size
    62cm, 24 3/8, 7 3/4
    63cm, 24 3/4, 7 7/8
    64cm, 25 1/4, 8 1/8
    65cm, 25 5/8, 8 3/8
    I hope this helps. Thank you,
    Jim B
    XSportsProtective
    (800)930-4084
    www.XSportsProtective.com
    [email protected]
    I wear a specialized max helmet, it says it goes from 56 to 64cm.
    To follow up on my original post, the helmet finally came in last week. The Lazer Sport O2 road helmet. I picked it up on Sat. I haven't taken it on a ride yet, just a test fit at the store and house but so far it seems to fit well. The adjuster snugs it up easily and it fits comfortably. I'm not super enthused by the way it sits on my shunt, but considering the fact that I literally have a small knob on the side of my head, I'm relatively certain that will be an issue regardless of helmet mfg. Don't know if I will or even can do anything about the fitment in that spot. Not without compromising the helmet itself. Other than that it certainly looks good, aside from looking like a mushroom head (feature).
    Later on down the road if I'm able to actually try on some other XXL helmets and they fit better, I'll keep this one as a spare. I doubt that I'll find something that is much better than this but we'll see. Fortunately I have an "in" at the LBS so I got the helmet for 10% over cost, so I wasn't out that much.
    Just wanted to keep you guys updated, I just recieved the Giro Feature and it FITS!!!!!! The sizing indicates up to 63 cm but for some reason it fit's my big, unusaully shaped noggin. And it fits well, my head fits "inside" the helmet. The sides and back have more coverage than others I have tried. Just to give you guys and Idea below are helmets that I have tried:
    Fox Flux - XL - I could not even get it to fit
    Fox Striker - XL- same as the Flux
    661 Recon - XL - same as the Fox
    Giro XAR - XL - not even close
    Giro Xen - XL - fits smaller than the xar
    XLV - fits but it was HUGE
    Bell Sequence - fits but its on top of my head, no real coverage on the sides and rear - I ended up settling for this since no other fits - till now
    Jan 2011
    finally got a Specialized Vice XL..fits nicely
    Dec 2011
    I have a large noggin as well. I went with a Giro venti from the lbs as it was the only thing in stock and cheaper (I paid about 50$ for it). I wish it had better air flow but it is a good cheap option.
    Feb 2012
    I bought a cheapola helmet and just moulded it with a knife
    I received my Giro Feature and it fits! My huge head actually fits in the helmet and it's not just sitting on top of my head.
    Reputation: armoredsaint's Avatar
    good thread for my big noogin too
    2012 Trek Fuel EX8 - Matte Black
    Reputation: DragonMTB's Avatar
    Sep 2012
    Uvex helmet comes with XXL which is 62-64cm....looks like these are only available in Europe....
    Pic
    Natural Born Killer
    Reputation: nemhed's Avatar
    May 2010
    I realize this thread started some time ago but it's still relevant. Like others I've got a grande cabeza in the 62cm, 7 3/4 size range. My problem with most helmets is my head is long from front to back rather than just a big round pumpkin. I'm currently riding with a Bell XLV. I'm happy with the fit, but it's getting a bit long in tooth. I'm looking for a helmet with a little better rear coverage like the Giro Feature. Just wondering if anyone's head has a similar shape and what helmets might fit my needs.
    Quote Originally Posted by Skrufryder View Post
    Silly rabbit Jack Daniel drinking donkey kissing caterpiller
    Sep 2012
    My head is the other way, wide with flat head in the back so like square head.....so if the shell is not round (that's why I can't fit into any helmets from Europe) then I can't fit in.....I wish Feature, Flux or Transition helmets come with 64-65cm sizes...
    Sep 2012
    Quote Originally Posted by nemhed View Post
    Have you seen POC helmets....try their XL-XXL size, may work for you...
    Dec 2013
    POC helmets are expensive - $150+
    Cratoni Velon Helmet $50 (59-62)
    Best bang for the buck is the Giro Venti XL for $30
  1. Took a good whack to my noggin... how you determine helmet replacement?
    By sbpinnacle in forum Apparel and Protection
    Last Post: 12-27-2009, 02:07 AM
  2. VOAZ and Irregular
    By Blatant in forum Arizona
    Last Post: 02-23-2009, 12:57 PM
  3. Look at that noggin....MAN that thing's HUGE!
    By jimboyzguy in forum Clydesdales/Tall Riders
    Last Post: 07-18-2007, 10:16 PM
  4. Helmet for Large Noggin?
    By Eastcoaster in forum Apparel and Protection
    Last Post: 02-10-2005, 04:21 PM
