Wrist tendonitis & Wrist Support- Mtbr.com
Results 1 to 18 of 18
    Aug 2016
    Hi!
    I do general trail riding / XC riding, I am a musician (professionally , so need my wrists badly) and have some inflamation, tendonitis in my left wrist, and in addition I just would like to protect and support both as much as possible.
    I am in physical therapy strengthening them and I am using some serras gel gloves to cushion but I am wondering what you guys would suggest as far as wraps / wristguards, and handlebars.
    Specifically I am curious about :
    Six six one wrist wrap pro
    Troy Lee Designs wrist support wrap
    open to any and all glove, handlebar, and wrist wraps/guard suggestions to help me ride and not worry about jeopardizing my career or creating more issues for myself
    Thank you!
    turtles make me hot
    Reputation: NYrr496's Avatar
    I was getting pain in my right wrist on long rides since a broken forearm 20+ years ago and the doctor setting the bones wrong.
    I tried a few different things and ended up settling on Jones Loop H bars. the swept back hand position did it for me.
    I am running mine with Lizard Skin Peaty grips but I'm about to try Jones foam grips for a little more comfort on my rigid fat bike.
    I like turtles
    Jul 2015
    Esi chunky grips dampen a a lot of shock and make a huge difference. I run the extra chunky which are 4mm thicker. I wear XL gloves.
    Demon Cleaner
    Reputation: Structure's Avatar
    Rather than a padding issue, consider alignment. Ideally, trail feedback should transmit up through your skeleton. If your wrists are bent and acting as flex joints/shock absorbers then they will eventually get overworked and inflamed. Try modifying the angle of your brakes and shifters so that your wrists are "nearly" strait in an attack position. There is more advise about this online (on mobile now and can't google it for you).
    Bicycling is politics by other means.
    Reputation: TrailGoat's Avatar
    Sep 2016
    Quote Originally Posted by Structure View Post
    try this.
    I recently put the "hand pad" grips on my bars to have more surface area on for my hand to rest on. the problem was, I had them rotated too low so my wrist was too bent (not actually bent much, but I guess more than they should be), and actually had my hands start to go numb on longer rides. after messing with the them a bit, I got them to a place that seems to work
    Quote Originally Posted by waterkress View Post
    Hi!
    Thank you!
    I have been riding with TLD wrist supports for several years now. I didn't have tendonitis, my main reason was to keep wrists straight and as fall protection to avoid broken wrists. I love them and they easily fit over my riding gloves.
    The bad part of using them is that I have become dependent and so now if I ride without them my wrists get sore sometimes.
    Dec 2014
    Hi!
    Thank you!
    You should also consider stem length, bar height and sweep.
    I have worked a lot to get my cockpit setup work for me using different stem lengths and bar heights.
    I've seen a lot of XC setups around and they are often quite agressive and makes the rider lean forward to be more aerodynamic. Mine bike was like that as well.
    If you have a too long stem and bars that are not high enough you will feel it in your palms and eventually in your wrists.
    With a shorter stem and a higher bar you will get less strain in your palms and wrists as you would be in a more upright position, and it will be better for your back and neck as well. It has helped me a lot. Now I don't have any pain in my wrists, back or neck anymore. It just feels great and also for long rides.
    With a too short stem you can get into trouble with seat position if you end up setting the seat too much backwards to get a comfortable position. You will then probably end up feeling pain in your hamstrings after a ride. A too high bar will not be good for you either. You would need to find the sweetspot that would work for you.
    Good luck!
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    Is your wrist bent back too much? Try rotating your brake levers down your wrist is flat across the back of your hand (or even a tad further, so that your fist is tilted slightly down), for the most common position during your ride - this is the strongest position for your wrist, and this is how boxers are taught to throw a punch. As the brake lever gets lower, it can be harder to reach when you are WAY back, behind the saddle for a steep drop, but, that's a different problem. I'd bet you'd prefer to get away from the wrist pain first.
    I'm late to this thread, but try some alt bars like Answer 720 20/20.
    https://www.answerproducts.com/compo...on-720-enduro/
    Not cheap. I found them on Pricepoint on close out for $80. Now that I have I would willingly pay full price. Puts your hands in a more natural position.
    Few other companies make them. I found a Niner bar on closeout as well and picked it up.
    Ripley LS v3
    OG Ripley v2 handed down to son
    Dec 2014
    Quote Originally Posted by TwoTone View Post
    I've heard that good carbon handlebars are doing a great job for hand and wrist fatigue.
    The Spank Spike Vibrocore alu bar is also known for doing a great job with that.
    But before investing in a expensive part I would reccomend getting the cockpit setup "correct" for the OP first. Your bar height might not be correct for him.
    I have been doing trial and error for a long time now with different stems (lengths and angles) and bars (widths, heigths and sweeps) before I got the cockpit perfect for me. The "journey" has cost me some $'s but I've learned a lot though.
    Edit: I also agree with other posters here about the brake lever angle. Dial it in so it feels natural to use the brakes. I assumed that the OP had a perfect angle as it is the first thing that I adjust on every new setup.
    Aug 2016
    Well, ergonomics and damping aside, for pure wrist protection, I am a fan of EWS wristler gloves. They extend up the wriat with a plastic insert and velcro strap that serve as a compression wrap and help resist over extension. They are very hot and may be overkill, but I like them for aggressive riding. The plastic insert can rub the top of my knuckles at times and create hot spots.
    The MTB Lab
    Reputation: pastajet's Avatar
    I've been happy with my SQlab setup: Review ? SQlab 311 Handlebars, 411 Innerbarends and 711 SY Grips
    I have bad thumb arthritis and wrist issues.
    Quote Originally Posted by pastajet View Post
    Funny I never thought I'd be one of those people, but I have to say I prefer the 20 degree sweep of the Answer bars.
    I purchased a set of Niner bars (17 degrees backsweep) because they were on closeout and though 3 degrees isn't that big of a difference- but I notice it when I ride the bike with the Niner bars.
    Ripley LS v3
    I $uck, but MY BIKE Rules
    Reputation: SparkyAlumni's Avatar
    Also a little late to this thread, but, I wanted to chime in.
    I'm in my early 40"s and I have bone spurs and other wrist issues (lots of sports injuries in my younger years). I've been riding Ergon grips for about 7 years now and most recently (in the last year and 1/2 or so), I've been using the Ergon GS1 (small) on ALL my bikes... my DHR, my Uzzi and my Tracer. At first they feel a little weird, but, IMHO, have no affect on my riding... I ride numerous days in a row and for hours at time, and with these, I no longer do I have the nagging "day after" soreness. I also haven't had any problems on South Mountain DH runs, or in Snow Summit/Big Bear, CA (bike park).
    Check them out: Products ? ERGON BIKE
    (if these seem still a little to big, they have newer grips called GA and GE)
    Best of luck.
    I Hate when the trail trips my bike! :skep:
    The MTB Lab
    It's more than just the backsweep, it's the synergy of the rise, forwardsweep, upsweet and backsweep. I did a review and used the 20/20 for a long time, but found them tough to use on super techy terrain: Answer Products Carbon 720 Enduro 20/20 Handlebars
    Ergon Bike
    Reputation: ERGON's Avatar
    Nov 2006
    Check out the link below, then scroll down.
    What causes hand pain and what can I do to combat it?
    Reputation: ryanmj's Avatar
    Aug 2014
    Quote Originally Posted by Chicane32 View Post
    ESI are the only grips that help my arthritis/tendonitis
    Jun 2013
    I think you should schedule a really good bike fitting, like one done by a physical therapist/bike fitter. They exist. Where are you located?
    This fitter is a good example. I've known her for several years.
    http://gorgebikefitter.com
    And this guy is in New York, but I just googled.
    Bike Fitting
    2018 Surly Karate Monkey 'dingle' speed
    2013 CAADX 105
    2012 Pinarello Quattro
    2002 Zurich LeMond
  1. Mio Alpha Wrist HRM
    By Lefty2341 in forum GPS, HRM and Bike Computer
    Last Post: 08-19-2013, 09:53 AM
  2. Wrist fracture prevention with wrist brace?
    By jared_j in forum Rider Down, injuries and recovery
    Last Post: 08-13-2013, 08:43 AM
  3. De quervain's wrist tendonitis
    By sportsmed in forum Rider Down, injuries and recovery
    Last Post: 07-02-2013, 06:10 PM
  4. Anyone try the 661 wrist support for lift days?
    By gticlay in forum Downhill - Freeride
    Last Post: 05-18-2012, 12:05 AM
  5. Do wrist guards actually prevent your wrist from breaking?
    By LoneReaction in forum Apparel and Protection
    Last Post: 09-02-2011, 09:50 AM
