Will Magikshine fit on Dinotte helmet mount?- Mtbr.com
Results 1 to 6 of 6
    Anyone know if the Magicshine will fit on the dinotte 200 helmet mount?
    Reputation: pop_martian's Avatar
    I think I remember reading that it will. It was in one of GeoMan's posts.
    "Donuts. Is there anything they can't do?"
    I have tried it and it should work well. However, you will need a smaller diameter o-ring with a smaller cross section. This should be easy to find locally.
    Reputation: johnnyspoke's Avatar
    Works with mine. Haven't used it that way much, the magicshine is usually on the bars while the 200L is on the helmet.
    I'm looking forward to regretting this.......
    GeoMan
    Reputation: GEOMAN's Avatar
    Quote Originally Posted by pop_martian
    Yep, it will.
    Geo
    GeoMan
    We Ride!
    www.geomangear.com
    ...Option #2 : Buy one of the adapters sold by EL34 and mount it using the old style Marwi helmet mounts. With one of these the light should be very easy to tilt-adjust. The strap system with the Dinotte 200L helmet mount is very nice though. The strap with the Marwi mount is just a single piece of Velcro. Which would work better would depend on your helmet and how the vent holes line up. If this is not an issue I don't know which system would be better but IMO, ...easy tilt wins out over anything using an O-ring. The 200L uses an O-ring and I always had fits getting it set just where I wanted it.
