wicking skull cap- Mtbr.com
Results 1 to 11 of 11
    Positively negative
    wicking skull cap
    I know it's the wrong time of year to be thinking about it, at least in some parts of the country (though it was 86 here today), but I'm looking for a skull cap to solve two problems.
    First, I sweat excessively and need something to keep the sweat out of my eyes. I have been using a Halo headband which works ok, but I still have to stop and wring it out a few times a ride in the summer heat.
    Second, I keep my hair (what's left of it) very short and tend to get burned on top of my head and want something to help with that. Though I will say I'm not specifically looking for something made specifically to block the sun, sweat management is the main goal.
    Does anyone know of a very light skull cap that will help keep the sweat running down my head without trying to cook my brain?
    Reputation: d365's Avatar
    Halo makes one. Something that works as well as the halo strip, but doesn't get saturated.... will be pretty damn thick.
    Reputation: coolhand80's Avatar
    Oct 2011
    Quote Originally Posted by big_papa_nuts View Post
    This is what I use. Works perfectly and helps keep me cool as it wicks the sweat away. I also sweat excessively and can't ride without one or my eyes will burn from sweat.
    https://www.underarmour.com/en-us/me...rap/pid1254900
    Reputation: OwenM's Avatar
    Oct 2012
    Buff. Use them at work under a hardhat and for everything outdoors until temps get around freezing and the beanies come out.
    I use a Halo skull cap and another product in combo. Can't think of the name now but it might be something like "Sweatbuster". The "Sweatbuster" is a massive thick pad, you could probably DIY with a maxi-pad, that Velcro in place to the forehead position of your helmet liner. Similar to your experience, I had to wring out the Halo during rides, but adding the "Sweatbuster" solved the sweat problem for me. Do a search for the sweatbuster on MTBR and you will find a thread or two.
    No Clue Crew
    Apr 2005
    I live in Phoenix and sweat a lot. I used to use several of the products mentioned, but have switched entirely to Sweatbusters. Much, much more effective product though it does nothing to shield your cranium from the sun. I suppose you could use it in conjunction with a skullcap like X Armor or whatever.
    Just like a raindrop, I was born to fall.
    Rent this space for $
    Reputation: Oh My Sack!'s Avatar
    Custom Performance Wear | SweatVac Performance Wear
    I have several, now and wear it every time I put my moto helmet or bike helmet on.
    Reputation: JNKER's Avatar
    Feb 2016
    It won't help for sunburn but for sweat, I've found nothing better than the Sweatbuster.
    Trax Factory - The Orignal Sweat Buster - Bike, Climbing, Hard Hat, Welding and Harness Helmet Sweat Absorbtion System
    Feb 2016
    Sep 2014
    I tried most of the rest, then got the best:
    Assos roboFoil Cap - Hats & Caps | Competitive Cyclist
    Ibis Ripmo
    Ibis Ripley V4
    Ibis Mojo HD5
    Pivot Mach 4SL
    Pivot LES SS (loaned out)
    A road bike
    Jan 2013
  1. Absolute best moisture wicking tops?
    By mrsa101 in forum Apparel and Protection
    Last Post: 08-30-2015, 08:57 PM
  2. Any data on wicking base layer effectiveness?
    By CrozCountry in forum Apparel and Protection
    Last Post: 08-07-2015, 05:14 PM
  3. Recommendation for do-rag skull cap?
    By johnb in forum General Discussion
    Last Post: 09-03-2013, 12:34 PM
  4. Skull fracture.
    By HOV in forum Apparel and Protection
    Last Post: 07-13-2012, 07:06 AM
  5. Casual wicking T with zipper and/or rear pockets?
    By danK in forum Apparel and Protection
    Last Post: 08-17-2011, 03:42 PM
