what shoes can I use?
Printable View
  • 05-14-2006
    stjump_lane
    Just bought a new bike, first one in ten years. It came w/ shimano m520 i think or m570, kinda bad eyes, can't distinguish. Do I need a certain shoe to fit this pedal or any shimano will do? Thanks
  • 05-14-2006
    Guyechka
    Any shoe that is made for clipless pedals will work. All you need is to have the little holes on the bottom to bolt the cleats into (it should say "SPD Compatible").
  • 05-14-2006
    stjump_lane
    Is that something else I need to buy(cleats), or do they usually come w/ the shoes?
  • 05-14-2006
    dumpy
    the cleats come with the pedals
  • 05-15-2006
    Guyechka
    Let me try to explain this. Every cycling shoe maker creates shoes with little holes in the bottom of the sole for the cleats to bolt onto. That means you could buy from Diadora, Shimano, 661, Lake, and the list goes on. The shoes will say "SPD compatible", which means that you can use them with clipless pedals. Although "SPD" refers to Shimano's patented clipless design, all other clipless pedal makers conform to the same cleat size. Therefore, all cleats will bolt onto the bottom of whatever "SPD Compatible" shoe you buy. When you buy pedals, they will come with cleats that are specific to that pedal design. If you buy Ritchey, you'll get Ritchey cleats; Crankbrothers will have Crankbrothers cleats. But, rest assured, the cleats will bolt onto the bottom of your shoes.
    You can buy Lake shoes and use them with Crankbrothers pedals without a problem. If you buy Shimano pedals later on, then you just have to switch the cleats and they will work with the Shimano pedals just as well.
  • 05-15-2006
    Cyberfyn
    Excellent and informative answer :thumbsup:
    I was just about to post a similar question when I read this.
    Ian F.
