What can i do (armor needed)- Mtbr.com
Results 1 to 19 of 19
    IMAG0134 by terrasmak, on Flickr
    What can i do to keep this from happening again. XC bike, foot got knocked off the pedal it seems like i clipped the outer chainring. Really pissed about the tat, i don't thing shin guards would really keep this from happening as this is the side of my leg. Open to suggestions.
    RideDirt
    Reputation: aedubber's Avatar
    ankle guards or even longer socks
    Ouch dude.
    dang that sucks....I would think shin guards would help even just a little bit...Maybe those knee pad/shin guard combo would work, Like the new kali aziz, fox makes a set too.
    Mar 2011
    six six one evo shin pads seem to wrap around your entire leg, check those out, and like he said above some longer socks would probably help some.
    Reputation: veryavgwhtguy's Avatar
    Switch to 1x9 or replace the outer ring with a bash guard. Do you really use the big ring that much?
    Five is right out
    If you are riding flats, consider clipless. It'll give you much more secure foot placement. Otherwise, some of the heavier duty shin guards give full wrap protection, but are very hot.
    The bashguard suggestions are good too.
    veryavgwhtguy nailed it - 1x9 or 2x9 with a bash will keep that from happening.
    Reputation: dclxvi's Avatar
    Like they say -> get a bash guard !
    Bashguard is out, i ride my bike on the road a lot, and need the large chainwheel. I have a clipless setup at home, i'm not comfy riding them thru all terrian at this time. I would have crashed yesterday a few times if i was riding with a clipless setup.
    Sixsixone Veggie Shin Guard at JensonUSA.com kinda wondering if something like this would work? Probably only wear one on the RT side.
    What is the lightest shin armor that will also protect the side of my leg?
    Great advice here.
    Additionally: I moved to thin flat pedals from a DMR Mag V12 and notice an improvement in feet staying on the pedals. They simply don't roll as easily, on both tricky ascents and rough downs. FWIW.
    Mike
    Reputation: snowpunk's Avatar
    I was using the SixSixOne Comp Knee/Shins for a while and they offered great lower leg protection. They wrap almost all the way around the leg and protect the calf and sides pretty well with padding.
    clipless pedals are the best..i ride thru all terrain even if i fall lol
    Clipless may have worked, but the hit i took bottomed out the suspension and my foot hit a root. My foot hitting the ground actually was a hard enough of a jolt to tweek my back.
    Reputation: cerebroside's Avatar
    Quote Originally Posted by terrasmak View Post
    Bashguard is out, i ride my bike on the road a lot, and need the large chainwheel...
    You can get big ring compatible bash guards, I know Blackspire does one.
    Quote Originally Posted by cerebroside View Post
    Thank you, checking them out. I did order a set of Lizard skins from the LBS today, will probably only wear one.
    Blue Pig
    Reputation: Blksocks's Avatar
    Dec 2009
    Feed that animal tat so it doesn't need to feed for blood again.
    Ragley Blue Pig
    Quote Originally Posted by Blksocks View Post
    Should have posted the rest of it, its a fuzzy little bunny.
    Rabid Lana Fan
    Now it's a fuzzy little bunny with spots.
    rOCktoberfest 2015 pt I here
    rOCktoberfest 2015 pt II here
  1. Help on Elbow/Forearm armor needed
    By rhynohead in forum Apparel and Protection
    Last Post: 06-21-2011, 04:29 PM
  2. Another Armor Thread. Best Leg and Arm Armor
    By Alpenglow in forum Apparel and Protection
    Last Post: 12-19-2007, 06:38 AM
  3. Replies: 2
    Last Post: 03-24-2006, 02:11 PM
  4. Replies: 0
    Last Post: 03-10-2006, 10:10 AM
  5. Armor Holdings Could Boost Humvee Armor Output 22%
    By gmaki in forum Apparel and Protection
    Last Post: 12-11-2004, 09:11 AM
