• 08-16-2011
    terrasmak
    What can i do (armor needed)
    IMAG0134 by terrasmak, on Flickr
    What can i do to keep this from happening again. XC bike, foot got knocked off the pedal it seems like i clipped the outer chainring. Really pissed about the tat, i don't thing shin guards would really keep this from happening as this is the side of my leg. Open to suggestions.
  • 08-16-2011
    aedubber
    ankle guards or even longer socks
  • 08-16-2011
    Irishcarbombs
    Ouch dude.
  • 08-16-2011
    savagenative
    dang that sucks....I would think shin guards would help even just a little bit...Maybe those knee pad/shin guard combo would work, Like the new kali aziz, fox makes a set too.
  • 08-17-2011
    carrlf
    six six one evo shin pads seem to wrap around your entire leg, check those out, and like he said above some longer socks would probably help some.
  • 08-17-2011
    veryavgwhtguy
    Switch to 1x9 or replace the outer ring with a bash guard. Do you really use the big ring that much?
  • 08-17-2011
    womble
    If you are riding flats, consider clipless. It'll give you much more secure foot placement. Otherwise, some of the heavier duty shin guards give full wrap protection, but are very hot.
    The bashguard suggestions are good too.
  • 08-17-2011
    CharacterZero
    veryavgwhtguy nailed it - 1x9 or 2x9 with a bash will keep that from happening.
  • 08-17-2011
    dclxvi
    Like they say -> get a bash guard !
  • 08-17-2011
    terrasmak
    Bashguard is out, i ride my bike on the road a lot, and need the large chainwheel. I have a clipless setup at home, i'm not comfy riding them thru all terrian at this time. I would have crashed yesterday a few times if i was riding with a clipless setup.
    Sixsixone Veggie Shin Guard at JensonUSA.com kinda wondering if something like this would work? Probably only wear one on the RT side.
    What is the lightest shin armor that will also protect the side of my leg?
  • 08-17-2011
    She&I
    Great advice here.
    Additionally: I moved to thin flat pedals from a DMR Mag V12 and notice an improvement in feet staying on the pedals. They simply don't roll as easily, on both tricky ascents and rough downs. FWIW.
    Mike
  • 08-17-2011
    snowpunk
    I was using the SixSixOne Comp Knee/Shins for a while and they offered great lower leg protection. They wrap almost all the way around the leg and protect the calf and sides pretty well with padding.
  • 08-17-2011
    skittles8810
    clipless pedals are the best..i ride thru all terrain even if i fall lol
  • 08-17-2011
    terrasmak
    Clipless may have worked, but the hit i took bottomed out the suspension and my foot hit a root. My foot hitting the ground actually was a hard enough of a jolt to tweek my back.
  • 08-18-2011
    cerebroside
    Originally Posted by terrasmak View Post
    Bashguard is out, i ride my bike on the road a lot, and need the large chainwheel...
    You can get big ring compatible bash guards, I know Blackspire does one.
  • 08-18-2011
    terrasmak
    Thank you, checking them out. I did order a set of Lizard skins from the LBS today, will probably only wear one.
  • 08-18-2011
    Blksocks
    Feed that animal tat so it doesn't need to feed for blood again.
  • 08-18-2011
    terrasmak
    Should have posted the rest of it, its a fuzzy little bunny.
  • 08-18-2011
    net wurker
    Now it's a fuzzy little bunny with spots.
