What is the best small optic for a P7 helmet light?- Mtbr.com
Results 1 to 2 of 2
    The title says it all. Is there a decent optic that is tight enough for a helmet light and will fit in the one inch square aluminum tubing? The only thing that I know is the BOOM reflector and it's not too tight.
    If the answer is no is there anything for a MC-E? The MC-E BOOM is a little tighter than the P7 version. Any decent lenses that will fit the one inch?
    If there still are non good enough for a helmet light, what are some larger options?
    Always used the Boom for the P7 builds. Throw will need a larger reflector or lens.
    Best throw out of a 1 inch square tube will be the triple XP-E board from cutter or putting 4 XPE's in the housing.
    " width="549">
    MC-E have OK throw, but you will need to have someone else chime in on their favorite lens.
