Tight-ish 3/4 sleeve- Mtbr.com
Results 1 to 6 of 6
    meh?
    Reputation: Map204's Avatar
    May 2012
    I've been looking for a 3/4 sleeve jersey for a while. All the 3/4 sleeve I find are DH cut and frankly look really hot (heat hot, not Paris Hilton hot). A good example is the jersey the Yeti team has been wearing at the EWS. I don't need room for pads, I don't ride DH or enduro.
    Anyone have any suggestions, or know who makes the Yeti team's jerseys?
    Sent from my iPhone using Tapadapabapadoo-op
    2013 Chromag Rootdown
    2010 SC Chameleon
    2001 Specalized Rockhopper FSR
    Oct 2007
    I've been wishing for the same thing but have not really spent much time searching yet. My only experience with DH style jerseys is one from TLD. It turned out to be lighter than expected and actually quite ventilated but it's still just so much fabric! I had to find it in X-small so that it looks somewhat reasonable and not like a wind sail (sleeves are too short but I just slide them up). I'm really leaning more towards the semi-fitted stuff, exactly like you pointed out. Let's see what people can find...
    Apr 2013
    Unless you're built like graves i wouldn't expect to find the same fit as you see there. however royal racing makes a 3/4 sleeve that is more snug than the other 3/4 sleeves i've worn.
    Quote Originally Posted by Map204 View Post
    What I have done is buy a regular LS jersey and taken it to a dry cleaner / tailor and have them cut it down. You can get to any length you want that way and the LS jerseys are often cheaper than the short sleeve ones.
    Romani ite domum
    meh?
    May 2012
    Quote Originally Posted by literally View Post
    Yeah, that was my other thought. Obviously I'm not going to get cut overnight, but I'd at least like the sleeves not to be wind sails.
    2010 SC Chameleon
    meh?
    May 2012
    Just because I saw it come through my RSS feeds: http://feedly.com/k/1j65Nvn
    ONE industries atom jersey
    2010 SC Chameleon
  1. How tight is too tight.....seat post clamp?
    By rsolti13 in forum 29er Components
    Last Post: 07-24-2012, 07:17 AM
  2. Chain tension - how tight is too tight?
    By djork in forum Singlespeed
    Last Post: 10-14-2011, 04:02 PM
  3. Chain Tension - How tight is too tight?
    By Sarasota in forum Singlespeed
    Last Post: 09-05-2011, 12:11 AM
  4. Bolt on skewers. How tight is to tight??
    By vizsladog in forum 29er Bikes
    Last Post: 03-05-2011, 10:25 PM
  5. Tire clearance..how tight is too tight?
    By morandi in forum 29er Bikes
    Last Post: 01-14-2011, 10:28 AM
