Sooper Quick Buckle Question for Helmets- Mtbr.com
Results 1 to 6 of 6
    Reputation: lamp no 3's Avatar
    Hope Sooper Quick Buckle Question for Helmets
    I just bought a bell trespass helmet, real nice btw, and I was wondering...
    does the buckle have to be exactly or pretty damn close to the throat/adam's apple area, or can it be on the throat but below the edge of your jaw?
    In my case, when the helmet is tightened, the buckle is right below the curve of the right side of my jaw
    26'er GT Avalanche 3.0 Disc singlespeed oh yeah...
    Why is adjusting derailleurs like rocket science to me?
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Buckles fine just below the jaw line .
    oh and btw on teh manual it says
    Grab the helmet with both hands and twist it left and right. if the helmet fit's right, the skin on the forehead will move as the helmet moves. If id does not, then the helmet is too lose and unsafe for use
    I passed that test
    Now grab the helmet with both hands and try to roll it off the helmet completely or so far that it blocks vision or backward far enough to expose the forehead, then it doesn't fit right and it is unsafe.
    I passed that test but when i grab the helmet and move it backwards, my forehead is exposed, but I would thin it is impossible to pass that because no matter how hard I tighten everything, my forehead will still show.
    AZ
    AZ is offline
    Did you get extra pads with your helmet? If you did you can use them to adjust the fit .
    nah
    AZ
    AZ is offline
    Not on backwards , right?
