shoe cleat stripped- Mtbr.com
Results 1 to 9 of 9
    shoe cleat stripped
    What must I do to fix my shoe? I recently started using clipless and I think I may have stripped something when installing my cleat... it has worked up until now which is only a few rides in.
    Image attached... not sure what I can do about this?
    Attached Thumbnails Attached Thumbnails shoe cleat stripped-img_20110923_132446.jpg
    West Chester, PA
    The insert inside the shoe is usually accessible and replaceable, just take out the insole and see if you can pull it out. You should be able to get a replacement easily from the manufacturer of the shoes.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Did you blue locktite the screws? They have been known to loosen and be lost.
    I didn't locktite the screws... I remember when I was tightening I think I stripped it... and it worked for a couple rides until it came out.
    Here is the problem... lake cycling has a new website with no contact info. The only contact info I could find was for velticsports.com and the email was undelivered..... These are mx101 Lake shoes... are the inserts pretty much standard?
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by aluminex View Post
    The cleat plates are fairly standard.
    There should be two sets of holes in the plate. Just emove the cleat and turn the plate around.
    I use antiseize rather than loctite on the threads.
    Veltec (parent company for Lake) closed down last month.
    mtbtires.com
    turtles make me hot
    Reputation: NYrr496's Avatar
    You should be using Loctite and some kind of a thin shield under that cleat as well. I agree with Shiggy... You should be able to use the second set of holes.
    I like turtles
    Reputation: Shalom's Avatar
    Nov 2008
    Either that or a lot of the time Shimano provide the base plates with the cleats. Alternatively, your LBS should have a bunch lying around somewhere if Shiggy's suggestion does not work out for you.
    Gigantic Hawk
    Reputation: dubthang's Avatar
    If you ride in watery/muddy areas on a regular basis, I wouldn't use Loctite. You'll never get those bolts back out. A little bit of grease, and regular checking of the bolt tightness should be fine.
    Quote Originally Posted by dubthang View Post
    Yep, grease is always good on bolts that are subject to water. It will keep the bolt from seizing, and if it is tightened the bolts really should never back out, but checking them periodically is always a good idea.
  1. stripped cleat bolt
    By jeeper006 in forum Beginner's Corner
    Last Post: 07-13-2010, 10:23 AM
  2. Stripped SPD cleat bolt. Help?
    By gkl in forum All Mountain
    Last Post: 06-28-2008, 07:26 PM
  3. time cleat hex bolt stripped
    By brickhead in forum General Discussion
    Last Post: 04-29-2006, 03:24 PM
  4. Help with shoe/cleat
    By zul in forum General Discussion
    Last Post: 01-06-2006, 02:13 PM
  5. stripped cleat bolt
    By Trail Punk in forum General Discussion
    Last Post: 06-04-2004, 08:44 AM
