• 04-19-2004
    jboy54321
    Q: Best pro/comp shoes for eggbeater pedals
    I am trying to choose a new MTB shoe. I have got Eggbeater Twin Ti pedals and have been using them with my existing low-end Shimano "Sport" shoe. I had to do a lot of cutting away of the rubber sole to get it all working - and clipping in is still not as smooth as it should be.
    I am now looking to buy a high end comp/pro level shoe. Anyone out there using this combo that can recommend a model or give any advice?
    :confused:
  • 04-19-2004
    Pedalfaraway
    I use
    Specialized BG Pro shoes with eggs and have no problems. I have always used Specialized shoes so I can't offer any comparison to other brands. I have had the Comp and Pro shoes, and think they feel about the same. I'm not sure the pro is woth the extra cash.
  • 04-19-2004
    jboy54321
    Thanks.
  • 04-19-2004
    Jm.
    I'm using some Gaerne shoes that I just got for free ($150 value! :D ) with mine. They are more of an XC-racing type shoe, but they fit my foot really well. Don't be too turned off by "stiffer" shoes, if they fit your foot they'll work out great. I didn't try my leg eaters with my softer shoes (that I use for my SPDs) but I do know that I had to up the tension in my SPDs when I got the stiffer shoes, they wouldn't engage unless I upped the spring tension. They work fine with the legeaters though.
  • 04-19-2004
    jboy54321
    Gaerne shoes
    Thanks for the info. I am considering the 03 Gaerne Rey MTB shoe. Is this the same shoe you have (see att)? How true was this shoe to to your usual size? I am looking at a new pair on eBay - but I'm concerned to make sure they fit well.
  • 04-20-2004
    LowRent1
    Sidi Dominator
    :confused:
    Buy whatever fits you best.
    I love my Sidi Dominator 2. Not made anymore. The Dominator 4 is the current model. When mine finally give up I'll buy whatever the current iteration is. I love my Sidis.
  • 04-20-2004
    Wm. L.
    :confused:
    I think the first 4 of 5 steps for shoes with Crank Bros should be good fit, good fit, good fit, and cool/breathable. Especially if you go on several hour rides. #5 would be reading the instructions and using shims if you have to. I tried both of my shoes with my Crank Bros, and shims did more to get them working right than any cutting of rubber would. There could be exceptions, but I am quite sure my Crank Bros instructions said work with shims first.
    If you have the $ know that Sidi makes width choices as well as metric 1/2 sizes.
  • 04-20-2004
    Knut
    What Pedalfaraway said regarding Specialized Pro MTB shoes. Not only are they a perfect match to Egg Beaters but they're also very comfy and at the same time raceworthy shoes...
  • 04-20-2004
    Jm.
    Well, they fit MY feet very well. My friend uses some high end Answer shoes, and he always gets blisters if he has to "hike a bike" any distance, while I can ride and do a litte hike-a-bike with no problem. They seemed to fit my normal size just fine. Those shoes are very similer, but not the exact same model I think. Maybe due to the year-differences if anything...
