Progressive lenses for riding- Mtbr.com
Results 1 to 13 of 13
    Switching from Trifocals to progressives. First couple weeks great but can not currently ride. Is anyone else riding with progressives? Just received some blended bifocals intended for riding/skiing but the blend line is larger then lined bifocals. Been riding with lined bifocals for both skiing and biking for three four years. Shocked at the progressive working so well for normal use. Contacts/surgery not an option and major brands(smith, oakley,tifosi, maui jim, etcc not viable with +4.5 prescriptions most stop around +3. Any experiences out there?
    Jan 2016
    I have used progressives for say a decade--try not to ride with the newest pair but the pair older just to keep them decent-----have had no issues--but mine are progressive bi-focals--not tri-focal----Have you asked the optomitrist? That large blend line makes one wonder if the lab did a good job or not. I also cannot use those brands and do not use a inexpensive lab--costco--lens crafters--walmart etc.
    progressive is probably best way to go.. Lines have a very distinct zone of distortion and cause image jump when an object crosses between lens zones. Blended round bifocals use a round segment and distortion is in an arc. Also the blend zone is wider since the idea was to hide the sharp visible line. Blended are more about aesthetics than optics.
    A good wide zone progressive will give you a very smooth transition from distance to near. You will lose a bit of width of field in the mid-range but while riding it probably would not be very much noticed.
    Higher powers are tough in any sort of wrap sunglasses. Plus lenses are thickest in center and thin out at the edges. Too thin of an edge makes them break or not stay in the frame. Add to that a curve in the frame and it is nearly impossible to keep the lenses in a frame for a high plus Rx..
    Demon Cleaner
    Reputation: Structure's Avatar
    Iíve been living and riding in progressives for about 8 years. No real problems. Iím a fan of prescription Oakleys though they need to be fitted right. The cost is high but as long as your prescription isnít changing, it seems worthwhile to me.
    Bicycling is politics by other means.
    Thanks for the replies. Going to put a progressive lense in a pair of ray ban daddy o's. That frame is suppose to work well with high rx.
    Hi There!
    Reputation: TheGweed's Avatar
    I've been wearing and riding with advanced progressives for quite a while. What I do is, whenever I buy a new pair for normal life, I switch the old pair to my riding glasses. No issues.
    NTFTC
    Reputation: LyNx's Avatar
    I'd say you guys are damn brave TBH. Curious how "blind" you are that you find you need to have this ability when riding? Just ask as I'm at the stage where last check up a couple years ago they were trying to get me to change to similar, said absolutely no way - for riding you only need to be able to see sharp from about 8ft and out. I can still see close fairly well, just have to adjust the closeness a bit, but good enough to be able to read the bike computer on the handlebar etc. without issue.
    Quote Originally Posted by Harold
    You're doing mtbr wrong, you're supposed to get increasingly offended by the implications that you're doing ANYTHING wrong.
    Sep 2016
    Progressive, and progressive sunglasses, in particular, changed my life. It's terrific to be able to see my watch, bike computer and the trail.
    Mark
    Sent from my SM-G935V using Tapatalk
    2017 Yeti SB4.5c, stock, except for a Wolf 28T oval chainring
    Apr 2015
    LynX
    for me it is about the change of light. Riding out in the open, then switching to a forest covered trail or the sun setting I have a hard time picking up the line so i switched to wearing glasses for the first time in my life. 48 yrs old. the progressive helped enormously.
    for skiing, the area where i ski is known for bad lighting. and light powder, so there's that.
    Thanks for the reply, just short of 50 myself. You're talking about the glasses that change from clear to tinted when you go into the sun? Thought this was about progressive lenses, as in combining near and far sighted prescriptions into one lens, or at least that's what I'm talking about. My thoughts were I like the tech and imagined myself looking through the wrong part of the lense, just when it was not good and sticking my front wheel on something, or something along those lines.
    Quote Originally Posted by fleboz View Post
    LynX
    Apr 2015
    Yes, progressive lenses helps me with the lights change. "transition" aka clear to tinted lenses are on my list, but i was told to get used to the progressives first. I've had them for about a year now. Hitting shade all of sudden was difficult for my eyes to adjust quickly, I couldnt pick up roots or rocks or small change in direction of the trial. The progressive lenses helped me with that. Riding helped immediately, but it took some adjustment when i drove. I did go to a specialist, one of their focus is working with active outdoor types.
    I don't wear them all the time as i still have decent vision.
    Hi There!
    Not sure how much you know about advanced progressive lenses, but everything is in focus no matter where I look. I don't think I can look thru the wrong part of the lens. However, my main reason for wearing them when riding is: if I need them for normal life, why wouldn't I need them for riding? I wish I didn't that's sure, but I can't wear contacts due to my eye shape. Speaking only for myself here.
    NTFTC
    Reputation: Lone Rager's Avatar
    Dec 2013
    Quote Originally Posted by TheGweed View Post
    Not sure how much you know about advanced progressive lenses, but everything is in focus no matter where I look.....
    Definitely not true. Near stuff isn't in focus looking through the tops and distant stuff isn't in focus looking through the bottoms. Looking left and right in the middle is a bit wacky.
    Do the math.
  1. Riding glasses with swappable lenses
    By Stormwalker in forum Apparel and Protection
    Last Post: 06-08-2017, 01:06 PM
  2. Lenses for early morning/evening riding
    By camp10 in forum Apparel and Protection
    Last Post: 08-16-2016, 02:17 AM
  3. Anyone use photochromic (transitions) lenses for night riding?
    By zuuds in forum Lights and Night Riding
    Last Post: 10-20-2014, 08:04 AM
  4. Contact Lenses - super dry while riding!
    By SoWal_MTBer in forum Apparel and Protection
    Last Post: 04-17-2013, 10:45 PM
  5. Riding with Progressive/transition lenses
    By mtbmonk in forum Apparel and Protection
    Last Post: 11-12-2011, 06:17 AM
