pls HELP - do shimano shoes run wide ??- Mtbr.com
Results 1 to 5 of 5
    robust, yet smooth
    My Better Half got me some schweeeet sh!imano m-180s for xmas. The length seems fine but I've got the ratchet all the way tight on my smaller foot. They just seem a little wide and while your foot doesn't lose weight and I was wearing standard thin mtb sox due to an unseasonably warm day, it doesn't seem right to have no more adjustment range before they're even broken in. On a suggestion from the General board, I took off the buckle and no luck - there's only one screw hole.
    Size on the bottom of the shoe says 45-45T.
    Also, what's the deal on the "cleat" - i.e. the hex head bolts up front? Can I take them out or are there other options? I'm only vaguely a weight weenie, but I'm seriously considering throwing in aluminum bolts to save some weight - i mean, why not?
    thanks,
    -capt pearl
    Excellence is an art won by training and habituation.
    We are what we repeatedly do. Excellence, then, is not an act but a habit.
    ~ Aristotle
    "Faster equals more funner" -Ashwinearl
    Linoleum Knife
    Reputation: forkboy's Avatar
    Quote Originally Posted by capt pearl
    thanks,
    -capt pearl
    Go pick up a pair of insoles from Footlocker / WalMart. I have narrow feet, and have had to use insoles on almost every pair of bike shoes I've bought... except the ones I finally got in a narrow width.
    Do the toe spikes on the 180's even come out? My 150's were part of the rubber sole with a little metal stud on the end. Aluminum will last you about one ride in Moab before they are reduced to little aluminum shavings...
    robust, yet smooth
    Quote Originally Posted by forkboy
    Do you mean replacement insoles or a second one on top of the first?
    Anyone have any experience with the ones that you heat, press your foot into, and allow to cool, creating a "custom" footbed?
    Yeah, they're threaded. Moab riding would come under the heading of "nice problem to have" - I'm in mid-TN. You really thing the bolts would just disintegrate?
    gratzi,
    -capt pearl
    ~ Aristotle
    Linoleum Knife
    I've done it both ways - I think Specialized is the only shoe I have had to use 2 insoles. Most are OK with just one.
    I've got those custom footbeds in my ski boots. I hate them. They are great, until you go in for lunch and your boots get warm... then they loosen up.
    At least mine do - your mileage may vary.
    gratzi,
    -capt pearl
    If you never plan on using them, Just plug up the holes with super glue...
    robust, yet smooth
    At least mine do - your mileage may vary..
    Intersting - this would make them pretty useless, IMHO.
    -capt pearl
    ~ Aristotle
