• 01-04-2006
    capt pearl
    pls HELP - do shimano shoes run wide ??
    My Better Half got me some schweeeet sh!imano m-180s for xmas. The length seems fine but I've got the ratchet all the way tight on my smaller foot. They just seem a little wide and while your foot doesn't lose weight and I was wearing standard thin mtb sox due to an unseasonably warm day, it doesn't seem right to have no more adjustment range before they're even broken in. On a suggestion from the General board, I took off the buckle and no luck - there's only one screw hole.
    Size on the bottom of the shoe says 45-45T.
    Also, what's the deal on the "cleat" - i.e. the hex head bolts up front? Can I take them out or are there other options? I'm only vaguely a weight weenie, but I'm seriously considering throwing in aluminum bolts to save some weight - i mean, why not?
    thanks,
    -capt pearl
  • 01-04-2006
    forkboy
    thanks,
    -capt pearl
    Go pick up a pair of insoles from Footlocker / WalMart. I have narrow feet, and have had to use insoles on almost every pair of bike shoes I've bought... except the ones I finally got in a narrow width.
    Do the toe spikes on the 180's even come out? My 150's were part of the rubber sole with a little metal stud on the end. Aluminum will last you about one ride in Moab before they are reduced to little aluminum shavings...
  • 01-05-2006
    capt pearl
    Do you mean replacement insoles or a second one on top of the first?
    Anyone have any experience with the ones that you heat, press your foot into, and allow to cool, creating a "custom" footbed?
    Yeah, they're threaded. Moab riding would come under the heading of "nice problem to have" - I'm in mid-TN. You really thing the bolts would just disintegrate?
    gratzi,
    -capt pearl
  • 01-05-2006
    forkboy
    I've done it both ways - I think Specialized is the only shoe I have had to use 2 insoles. Most are OK with just one.
    I've got those custom footbeds in my ski boots. I hate them. They are great, until you go in for lunch and your boots get warm... then they loosen up.
    At least mine do - your mileage may vary.
    gratzi,
    -capt pearl
    If you never plan on using them, Just plug up the holes with super glue...
  • 01-05-2006
    capt pearl
    At least mine do - your mileage may vary..
    Intersting - this would make them pretty useless, IMHO.
    -capt pearl
