Plastic smell/taste in new hydro bladder.- Mtbr.com
Results 1 to 6 of 6
    Reputation: ...Mark...'s Avatar
    Feb 2016
    Quickest way to neutralize it?
    I'm doing a 24 hour lemon water soak currently. Any other suggestions?
    TIA.
    No Clue Crew
    Apr 2005
    I usually live with it the first ride and it's gone by the second.
    Just like a raindrop, I was born to fall.
    Reputation: vikb's Avatar
    Quote Originally Posted by ...Mark... View Post
    If the taste doesn't go away soon throw that bladder away and get one that doesn't have that problem. Camelbak and Nalgene are both taste free products.
    I've had some bladders and bottles that continued to taste like crap months after I started using them.
    Personally I don't even bother with plastic containers that taste bad. There are enough options with no taste issues I just start with one of them. If someone tries to give me a free bottle/bladder that has taste issues I just hand it back.
    Life is too short to be sucking back noxious chemicals each mouthful.
    Safe riding,
    Vik
    www.vikapproved.com
    Reputation: dbhammercycle's Avatar
    You can try to use a little white vinegar and water wash to see if that removes the taste. Be sure to suck it through the hose if you are not submerging it. That's what I would try first.
    A 24 hr soak may be too much, the acidity of the lemon juice may make the rubber/plastic more brittle sooner. That's why I suggest using a more dilute solution of white vinegar and water. I also wouldn't scrub it too hard with a brush, unless it has soft bristles. It's possible to scratch the material which could allow bacteria a foothold and then you will have to replace sooner. Also, a good air dry would be in order after the wash.
    I don't know why,... it's just MUSS easier to pedal than the other ones.
    BOOM goes the dynamite!
    Reputation: noapathy's Avatar
    Is this the Flopak from pricepoint?
    since 4/10/2009
    Reputation: Harold's Avatar
    Hydrapack reservoirs are also good, from my experience. I have a few Camelbak bladders, but don't use them much. Wife's not strong enough to deal with their twist closure, so I always wind up dealing with it. The Hydrapack bladders are something she can actually open/close, to they get more use.
  1. Ooh That Smell
    By milliesand in forum Apparel and Protection
    Last Post: 11-13-2015, 03:33 PM
  2. getting the funk smell out
    By goodmojo in forum General Discussion
    Last Post: 07-11-2015, 06:22 AM
  3. I put the Hydro hose in a non hydro cable routing!
    By SQUIRRELSHOOTR in forum Brake Time
    Last Post: 04-24-2014, 06:18 AM
  4. Replies: 33
    Last Post: 12-01-2012, 06:48 PM
  5. hydropak bladder foul taste
    By chang1701 in forum Apparel and Protection
    Last Post: 09-14-2011, 03:20 PM
