Phony helmet weight stickers- Mtbr.com
Results 1 to 6 of 6
    Did anybody ever notice how inaccurate the Giro helmets weight claims were?
    Just bought an E2 and a Xen and put them on the digital scale for fun.
    E2 sticker says 290g. Actual weight is 342g.
    Xen sticker says 336g. Actual weight is 321g.
    Go figure.
    Reputation: 006_007's Avatar
    No way. false advertised weight claims? Whats next, people cheating in the TDF?
    Reputation: Some Guy's Avatar
    Mar 2005
    Helmet stickers are generally quite accurate in my experiance.
    www.yourtrails.net/weights/ - Kick ass weights listing
    racing.thylacinecycles.com - Racing silliness
    If every manufacturer clearly stated actual weights of cycling products, what would we talk about on this forum?
    I think you should 'tune' the helmets by carving away foam with a kitchen knife. Sure, you'll lose some stiffness, but I've learned from this forum that stiffness does not matter.
    Wow- I just had a flashback! When I was a poor engineering student, I wanted a fancy new helmet with lots of vents, just like all the cool kids. I looked at the Bell helmets and realized that they used the same foam core on the cheap helmet and the high-end helmet. But, the plastic shell of the cheap helmet was missing some vent holes. Of course, I bought the cheap one and spent the next 4 hours opening the vent holes with an X-Acto knife. So, I guess I'm guilty of helmet tuning. I also tuned my car racing helmet by removing the visor ratcheting system and using aluminum bolts...
    Also remember that the claimed weight might not necessarily be for the size of helmet that you bought. I know of several outdoors shops that give the claimed weight in a set size, usually a smaller one so stuff looks lighter Possible that the claimed weight is for a small/med helmet, and if you have a larger one, hence the weight difference.
    Definatly quite likely tho that the manufacturer is shaving some weight in the claim tho...
    Tim
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    Or their claimed weight is for the bare helmet, no visor, no straps!
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
