Opinions on what is the best cold weather cycling jacket.- Mtbr.com
Results 1 to 7 of 7
    Sep 2015
    Sort of getting my wish list of cycling apparel figured out for next winter. I just got an ICT OPS and I know I have work to do in the garment area.
    I cycle in Iowa and it gets very gold on occasion. What are some of the best options for outer layer.
    Since I am sort of dreaming at this point money is not necessarily a consideration.
    Thanks for the feedback.
    Sep 2014
    If money is not in consideration, something with Assos written on it. And for your inner layer. And for your bibshorts/bibtights, and for your feet, and for your head, and, well, you get the idea.
    I cycle in Iowa too and this has been a mild winter. Foxwear is a really nice option, works well and is quite reasonable too, even in the really cold!
    Reputation: watts888's Avatar
    Oct 2012
    My wish list is breathable with armpit zippers, long sleeved to go to the gloves/bar mits, multi-layer that I can easily remove a layer, and moisture wicking base layer.
    20-30F range, I use a basic long sleeve jersey or t-shirt with arm covers and a light windbreaker. Once I start pedaling, no worry about being cold
    10-20F range, I used a polypropylene long-sleeve shirt and the same light windbreaker. At this temperature, it was more about keeping my hands warm.
    I haven't been out for a ride in less than that in Kansas City yet this year. Only been a couple days less than 10 so far.
    "a hundred travel books isn't worth one real trip"
    Class Clown
    Reputation: dundundata's Avatar
    I use a northface softshell ive had for about a decade. Its light with pit zips and also very warm. Most days i only wear a tshirt and bib with the jacket and stay plenty warm. Its also windproof and water resistant (not proof).
    Give'er!
    Reputation: MCHB's Avatar
    Jun 2014
    +1 for using a Northface softshell. Mine doesn't have armpit zips though, unfortunately. I usually carry a fleece in my pack in case I get cold, but I haven't had to use it yet. Once you start moving, it doesn't take long to warm up!
    Feb 2015
    I'm happy enough with my Sugoi RSE 260 softshell. It's windproof and will shrug off a good bit of water. It can get too hot on climbs unless it's a good bit below freezing but the type of layer that fits under it leaves my core a little cold if I unzip it.
    As often, I wear a powerstretch pro fleece hoody which works really well. Mine is a Salomon but there are a half dozen brands that are essentially the same. They breathe really well and let in enough wind to prevent you from overheating. I usually throw a windshirt over it to start and peel it off after the first big climb. It strikes a nice balance between insulation and breathability.
    Both have a cut and stretch that works really well on the bike.
  1. Cold weather jacket for dry conditions?? Recommendations please.
    By Zac808 in forum Apparel and Protection
    Last Post: 12-23-2014, 09:39 AM
  2. Looking for recommendations for cold weather riding jacket.
    By glorth2 in forum Apparel and Protection
    Last Post: 09-18-2014, 07:42 PM
  3. Good cold weather riding jacket?
    By dirtrider76 in forum Apparel and Protection
    Last Post: 12-23-2013, 10:59 PM
  4. Jacket for Cold Weather
    By rideHSV in forum Apparel and Protection
    Last Post: 01-02-2013, 08:16 PM
  5. Jacket for a cold / windy weather?
    By rafab in forum Apparel and Protection
    Last Post: 07-07-2011, 03:49 PM
