Need help with Troy Lee XC gloves sizing!- Mtbr.com
Results 1 to 8 of 8
    Reputation: LoneReaction's Avatar
    May 2010
    Caution;  Merge;  Workers Ahead! Need help with Troy Lee XC gloves sizing!
    When I wrap a tape around my palm (excluding thumb) it measures 8inches.However, when I measure the tip of my middle finger to base of my palm, it's only 7inches.
    Should I get a S or M?
    I've read almost all the threads on TLD gloves (forum search), but I'm still unsure. Unable to try them because no local stores sell them.
    Many thanks!
    Reputation: zenkem's Avatar
    I normally wear a Lg glove but had to get an XL when I ordered my Troy Lee Full finger gloves and my hand measures out to 9"...hope this helps...
    May 2010
    Thanks Zenkem! When you say 9", is it around the palm or from middle finger to base of thumb?
    I just bought a pair of Troylee XC gloves..
    my palm to tip of finger is just over 7"(less than 7 1/4)
    and I bought size large..they fit fine..
    I would say either medium or large.
    small is out of the question
    May 2010
    Alrighty, I'll try the medium. *cross fingers*
    Quote Originally Posted by LoneReaction
    FYI,
    How do I measure my glove size?
    Hold your palm out flat and use a tape measure around your hand at its fullest point, not including your thumb. Use the following chart to convert to standard glove sizing.
    http://www.pricepoint.com/helpDesk/P...izing%20Info#7
    May 2010
    Wow, that's a good page to bookmark =)
    pcv
    pcv is offline
    In glove-size I'm sometimes Small, sometimes Medium, having skinny hands with long fingers. So following this thread I got SE Gloves in Medium and .... it's still okay but could be smaller, should have gotten Small.
