Need helmet help, full face fit- Mtbr.com
    Reputation: phoenixsun's Avatar
    May 2010
    I ordered a remedy to size, the crown fit well, but the cheek pads were about 1/2" away. The helmet moved easily and would have been displaced in a crash.
    So, I order a medium, crown fit like a vice, the cheek pads touched, but the ill fit meant it could be displaced as well.
    Standard measuring I am 23.5",
    I need a full face that you really have to squeeze by the cheek pads.
    Any one know of such a fit?
    No one around here carries full face so I am stuck guessing.
    Thanks in advance.
    note to self, do not read rider down forum.
    habitual line-stepper
    Reputation: kanai's Avatar
    i tried on several helmets and the remedy fit me best overall. however, i had the same fit issue, going to thicker pads did the trick. you can order thicker pads to fit, check out universal cycles, lots to choose from.
    Universal Cycles -- Giro Helmet Parts
    Quote Originally Posted by vBulletin
    The server is too busy at the moment. Please try again later.
    May 2010
    Thanks, interesting, but I dont think the extra 5mm will do it.
    When you grab and tug on your helmet does it roll back above your forehead?
    there's a little play, but not like with the stock cheek pads. you must be reading the fit guide that came with your helmet, lol. i had a similar question earlier this summer after reading through that guide, which eventually led me to universal. its too bad you can't try on other sizes/brands. i probably tried 6 or 7 different helmets before going with giro. good luck!
  1. Convertible Full Face Helmet / XC helmet
    By Pimpride in forum Apparel and Protection
    Last Post: 04-15-2011, 08:42 PM
  2. Ordering a New Full Face Helmet. Any Input on This Helmet?
    By ECU_Pirate18 in forum Apparel and Protection
    Last Post: 06-29-2009, 05:45 PM
  3. Bell Full Throttle Full Face Helmet
    By mrpercussive in forum Apparel and Protection
    Last Post: 09-13-2007, 09:06 AM
  4. Bell Full Throttle Full Face Helmet
    Last Post: 09-13-2007, 07:49 AM
  5. Full Face Helmet Argument- here's an ear full!
    By Prof. Chaos in forum Apparel and Protection
    Last Post: 07-01-2007, 07:23 PM
